VETTE PROJECT DONE FOR NOW
bobcat5544
1978 VETTE With ZZ383 Crate Engine, Tunnel Ram Intake, 9” Ford 40 spline, Strange spool, 40 spline axels, gun drilled, Strange alum center section, big pinion, 4.11 Richmond pro gear
Sooo...you've had plenty of time to take it out since yesterday and tell us how it runs...so how does it run??
I did take it out yesterday just to have a little fun, but it only lasted 20 min since the police did not like the fact it had no plates, I exceeded the noise limit, I wheeled off the line, and exceeded the speed limit 92 IN A 55 MILE LIMIT.
OF COURSE IT WAS WORTH IT
but it hooked perfect off the line thrusting my balls into my throat, my next change will be the trans I need a different gear ratio, I got the feeling my trans is geared to high for 1/4 mile runs. This weekend I will be putting it on the dyno, and I will post the results on Monday, with out the blower I was pushing 650 hp 800 ft-lbs torque.
I think you need a test driver,don't you?
I know just the guy..........ME :lurk::confused::mad::nono::D
I know just the guy..........ME :lurk:  :confused:  :mad:  :nono:  :D
your almost correct, what I really is a test rider so if any one fit this discription then your hired
Female
Age 18-27 (if to old may have heart attack / to young I may go to jail I will have to check your state laws on age)
Under 120 lbs (I dont want too much extra wight in the car it may slow me down)
C CUP or larger (Just incase I have to hit the brakes hard she will have some Cushioning)
Ah shucks!!!! I don't meet those requirements :confused:
...amit... 2 outta 4... :confused:
... the middle two, to clarify for the sickos and Michael Jackson wannabees.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,262 Guests (See full list)
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
