Help! Any plumbers here?
RyanbabZ71
Ok this is my problem. As of a few wks ago my hot water pressure sucks. its at about 60-70% of normal flow. Cold water is fine. I have drained the hot water heater (clean water came out nothing out of the ordinary). The house is almost 4 yrs old. Also if I have the shower on and turn the hot water on in the bathroom sink the pressure on both drops even more. Any ideas?
Thanks!
I'm no plumber but if I had to guess it might be a bad pressure release valve on the hot water tank. It might be letting off too soon. Is there any water dripping out of it?
Do you have a water heater or just an on demand coil on the boiler? I would suggest the mixing valve on the boiler. If thats what you have. Are you on a well or town water? Well water tends to muck up fixtures and valves quicker. My water pressure sucked in the kitchen until I remodeled it over the winter and changed the faucet, not it rocks. Just all plugged up with sediment. I now run a filter.
Its city water with a water heater (30-40 gallon dont know off the top of my head). Our bathroom faucets and shower head are all about 3-6 months old and I wouldnt think they would get clogged that fast. I could see if they were old.
So its just the bathroom that has bad pressure? Is the pressure ok in the kitchen? It has to be a restriction in the bathroom plumbing somewhere. Have you tried running the kitchen faucet and flushing the toilet to see if the kitchen pressure drops? Thats an odd one. Home warranty?????
Thanks!
disconnect the flex pipe at the water heater outlet and look down the nipple into the heater. Also check the inlet side. You will probably find corrosion or some build-up in one of those nipples. There should be an anode rod in the heater, mounted somewhere
on the heater top and running down into the heater tank. Check it to make sure it's even there and that it also is not corroded. The anode rod is there to prevent electrolysis and corrosion. It sounds to me like there is some kind of corrosive build-up in the heater. Also, sometimes that junk can end up in the filter screens at the faucets and shower heads.
Ryan, we need to play 64 questions? 1. Did this just start all of a sudden? 2. Does it happen anywhere else in the house, kitchen, outside facuet? 3. I think you said you are on city water, if so has the city had any broken lines in your area? 4. Do you run out of hot water very fast?
Answers: 1. If it just started could be a couple of different things, bad pressure reducing valve, clogged areator on facuet.
2. If you have same problem in kitchen you run hot water in sink and when you turn on hot water in bathroom it points to some problem in hot water system. But check and see if you have the problem on both hot and cold water sides.
3. If you don't know about broken lines call the utility and ask them what kind of water pressure you should have at you house and then ask if they have had any problems in your area.
4. You could be a luck one! If you seem to run out of hot water very fast at all facuets, you will need to check the dip tube in your water heater, this is a plastic tube that is on the incoming water line when you pull the connector off you can stick your finger down in the line and pull it out, there was a problem a few years ago with these tubes failing and melting away.
Hope this helps if not post again and I will try again. :crazy:
Thanks for your help. It is throughout the whole house (kitchen etc).
1. Did this just start all of a sudden? Yes
2. Does it happen anywhere else in the house, kitchen, outside facuet? Every hot water faucet
3. I think you said you are on city water, if so has the city had any broken lines in your area? No
4. Do you run out of hot water very fast? No i can shower and it is all hot. Also the dishwasher ran and it had enough hot water
Cold water runs fine if there was a bad city line I would think also affect the cold water.
When I get a chance I will check the things you guys highlighted
Well, here's what I understand from reading the other posts.
1. Main water line to the house is fine
2. All cold water lines are fine
3. ALL hot water lines are NOT fine
4. It happened quickly
5. You still seem to have plenty of hot water, just really slow.
I'd say There is a plug in the line between the water heater and the first branch to the sinks etc.
Update:
Well last night I was going to take the inlet and outlet pipes off however the only way to do this is to cut the copper piping. While I was thinking how to tackle this I was hitting the pipe with a pipe wrench (not to hard). I decided to wait until the weekend when i had time and help at home to work on it. Well what do you know last night after the allstar game I went to take a shower and the water pressure was great again. HMM maybe I knocked something loose?
Ryan
I'm new here (I just joined yesterday) but I am a licensed plumber. If your going to go as far as cutting the pipes, just replace the tank they really don't cost all that much. How old is this tank? You might have hard water and have a calcium (or rust) build up inside the tank. If the pressure seems better now you might be better leaving well enough alone. But it might be a good idea to drain the tank. Shut off the cold water supply open a faucet on hot only and drain it. Be sure to shut off the breaker if it is electric or shut off the gas if it gas.
I'd try draining it if the problem re-arises. It should be drained once a year anyways. Usually the taps that are used are on the top so most of the time hot water is just "skimmed" off the top and the bottom remains stagnant and collects calcium and rust. Good luck.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
