2wd lift question
Hi. Im a newb to all this, came from an intense import scene need sumthin new. Here's my question I have a 01 gmc sierra extended cab w/ a short bed. I was doing some research on suspension lift and came across a suspension company Rough Country, I was looking at the 3in suspension lift package that comes with the spindles, shocks and the rear blocks for under $500 bucks. Has anybody used their product and if so any pros and con about it. And any suggestion on other suspension lift companies. And if anyone have pictures of their trucks with 3in lift. Any suggestion is greatly appreciated..thanks in advance
  • 5 weeks later...
I have that exact lift and i would give it a 4 out of 5. And the only reason I dont give it a 5 is because the shocks arnt the best and it will need tightening from time to time. It dramatically improved the overall look of my 2000 silverado. Remember though the alignment cost a lot. No one i went to had heard of the company and it ended up costing over a grand. best of luck
btw sorry no pictures-just look at a leveled Z71 on stock tires for an idea
Might be better off to look into a Fab-tech kit, for no other reason than the availability of parts and service.
Pat
I've seen some lifted trucks with new driveshaft is that required for lift over 6in.? And yea I'm still researching on the lift I want. Thanks again
I work with a guy that had a 7" fabtech on his '05 2wd ECSB, it looked pretty sweet, but my '02 2500HD ECSB with H2 wheels/tires and green keys was still an inch higher.
Pat
  • 2 months later...
:cool: I had an '01 Silverado Ext Cab 2WD that I had a FabTech 3" spindle lift installed on. Paired this with a set of ProComp 265's and the total added height was about 5 inches. Would have been enough for 33's or 285's easy without any trimming. Not too many manufacturers out their making lifts for us 2WD folks.
I agree with you there seen alot of product for 4x4 and lil for us 2wd
if u are only going for 3 inches, go for a body lift and just buy new shocks, much cheaper, and u can go for the bigger tires. do the 3" body, and soon you'll want a suspension lift, a REAL one, aka 6", so ull end up with 9 total. once u go up you never wanna stop :D
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
