Running Lean
What are some of the leading reasons why a TBI system would be running lean? My injectors spray pattern look good. When I pull the plugs they look very white and I definitely need more fuel. I replaced my O2 sensor a couple of years ago. Could a computer replacement help? Thanks!!!
Vacuum leak, bad MAF sensor, Lazy O2 sensors, worn injectors.........
A computer replacement would be a waste of time.
DEWFPO
You better have someone with a scanner thet reads instant data and read all the info to see if the vehicle is really doing what you think its doing. Just a clean plug isnt proof that the engine is running lean. Fuel can make the plugs look real clean. As fuel economy worse? Is there a driveability problem?
    mdh1053
    mdh1053
  • Who's Online   5 Members, 0 Anonymous, 1,372 Guests (See full list)
