Torsion Key Supplier
Can anyone reccommend a good place to get a set of Ford keys and/or aftermarket torsion bar keys?  Part numbers would help if you got 'em.
Thanks
CHEVY TORSION BAR CODES AND RATINGS:
15048307-LH (code XK) (Max torque 4553)
15048308-RH (code XK) (Max torque 4553)
15048309-LH (code XL) (Max torque 4626)
15048310-RH (code XL) (Max torque 4626)
15712407-LH (code WX) (Max torque 4863)
15712408-RH (code WX) (Max torque 4863)
15048311-LH (code XM) (Max torque 5638)
15048312-RH (code XM) (Max torque 5638)
15058267-LH (code YH) (Max torque 5913)
15058268-RH (code YH) (Max torque 5913)
15712409-LH (code WY) (Max torque 5913)
15712410-RH (code WY) (Max torque 5913)
15528957-LH (code GG) (Max torque 6709)
15528958-RH (code GG) (Max torque 6709)
15712411-LH (code WZ) (Max torque 7267)
15712412-RH (code WZ) (Max torque 7267)
15528963-LH (code GK) (Max torque 8615)
15528964-RH (code GK) (Max torque 8615)
15528965-LH (code GL) (Max torque 8782)
15528966-RH (code GL) (Max torque 8782)
15732338-LH (code XG) (Max torque 9054)
15732339-RH (code XG) (Max torque 9054)
15528959-LH (code GH) (Max torque 7161)
15528960-RH (code GH) (Max torque 7161)
Here is the Ford key part number:
XL3Z5B328CA
A good place to get them is Ford Parts Online
Thanks
XL3Z5B328CA
Hi, does the ford key part number above work for a 2005 Z71 crew?
Also, a quick question regarding torsion keys if no one minds. After adding them and turning the bars all the way down, to keep the ride as smooth as possible, it still lifts the truck as well correct? Does it lift it still above the rear?
Just curious if I'll be required to turn the bars any after adding them.
Thanks so much! I'm still learning.
Alan
