Install larger brakes
magduck
Is there a upgrade package for the disk brakes of a 96 yukon. If I tow my boat or tent trailer through the mountains I come out with hot, soft brakes and warped rotors coming down the mountain. I try to use my gears to keep my speed down, but on long hills and curves they get hot.
I don't know if you can get bigger brakes but I have put drilled and slotted rotors on my 03. With ceramic pads.
Stops on a dime!!
Cheers java script:emoticon(':cheers:')
smilie
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
