Scyry
Enjoy:
Yesterday I was having some work done at the car dealer. A Blonde woman came in and asked for a seven-hundred-ten. They all looked at each other, and the mechanic asked, "What is a seven-hundred-ten?"
She replied, "You know, the little piece in the middle of the engine. I lost it and need a new one. It had always been there."
The mechanic gave the woman a piece of paper and a pen and asked her to draw what the piece looked like. She drew a circle and in the middle of it wrote 710.
He then took her over to another car which had the hood up and asked, "Is there a 710 on this car?" She pointed and said, "Of course, it's right there."
Click here to learn the identity of the mysterious 710:
http://mademelaugh.com/gfx/710.jpg
  • 10 months later...
What is really bad is if they need a 710 cap for a Pontiac Gooole. (Pontiac 6000LE)
We actually had someone come into one or our stores needing something for a Gooole.
:loser::cool: That is just too funny!! WOW!!
    • I have a 2026 base 1500 "WT" regular cab. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit? [I listen to classical and it gets a bit raspy at slightly higher volumes.  Don't need a sub etc.] Do I have two or 1 speakers in the doors? Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
