trans slip on occasion?
2002 Chevy Avalanche, 1500, Z71, build date June 4, 2001 (very early production)
On a rare occasion (once every two or three months) when I start from a stop sigh or stop light the trans feels like it is slipping, the truck doesn't move much, and I instinctivly lift my gas foot and try again and all works fine. Someone else here at work (2001 or 2002 1500 Silverado) has the same problem. I am a two footed driver, but do not think that I have my foot on the brake at the same time as I am giving the gas. Any ideas?
Thanks
There is a known issue with the transmission slipping every once in a while. Mine will do it if it is hot and I go from backing reverse to drive. Knock on wood no problems with the tranny at 86k.
Larry
Thanks
My 03' does the same thing. The dealer thought I was crazy.....go figure.
Mine likes to try to start off in second sometimes before itfinally shifts to first. I hate GM automatics. :cheers:
I am so releaved to hear from you guys. My truck (2004 Sierra) does the same thing only about every 6 months. Does a little stutter when taking off from a stop or as I've found, turning right from a stop. GM dealer reprogrammed the PCM for me but couldn't verify the problem.
I've had one occasion when going in reverse. I drove for about 3.5hrs and when I got to my destination i was parking and the truck didn't want to more in reverse.
I am so glad I'm not the only one and not crazy.
Question- why does this slip not through any codes?
Jansen
if my temp gets up just a tick over where its supposed to be the trans slips and sends the pcm into the full pressure mode i just stop for about 10 mins restart and it goes away but at 170k ive figured ive been on borrowed tome for awhile now
Mine would start in 2nd after stopping at a light, then a little gas and it would downshift. It did this very rarely...like a few times a year. At 140K I had the trans completely rebuilt (FLT Level 4) and it still does it with about the same regularity. BTW, the built trans has a Transgo HD2 shift kit so no, it does not fix it. Never happens enough to worry about if you ask me.
Ha! The service bulletin says only a small % of trucks experience this. I'd guess that it only takes a small % of idiots to ruin GM engineering's reputation with denials like this.
Jansen
maybe it isn't slipping.
somebody else in this thread was hitting on the truck not always wanting to go into first gear.
My truck has lots of miles on it and when it would get good and hot after a long drive, sometimes it wouldn't go back into 1st range, was starting out in 2nd which makes it seem like a dog.
I removed tranny pan and checked both the shift solenoids, they ohmed out OK, so I cleaned them because they had a buildup of metal particles on them. its been OK ever since.
I've been in a car with server slippage and what I speak of isn't this. My grandmothers car had slippage so bad that the hood would bounce.
The truck is a very subtle slip that when it does it you get that adrenline rush and ask WTF was that? But then it won't do it for 6 or 8 months and you forget about it. I almost wonder if it is a gear selection problem and the truck isn't sure what gear to be in?
The dealership reprogrammed the PCM for me and updated a body control program. Not sure if this will fix it, but it is so rare that I won't know for a while.
Jansen
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
