Need torque spec
Anyone have the torque specification for the engine block coolant drain bolts? I need to do a coolant flush soon and can't find the proper torque info.
On bolts like these it is more important to prevent leaks rather than torquing them to spec. The bolt in this application acts as a plug not a structural fastener, so the torque spec will be low. I would coat the bolt threads with silicone sealer, and then tighten it snugly. That should do it.
I wouldn't even take those out if I was doing a flush. Just do it through the radiator a few times until it runs clear, then add the proper level of antifreeze.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
