Part number for fuel pump
I need help with which fuel pump to get. My friend has the same gmc truck as mine except his is 2wd and mine is 4wd. They are both 1998 gmc seirra 1500 with the 5.7 engines. His fuel pump went and was replaced with a $165 acdelco pump (#25163473).
When I called the dealer for my truck the tell me I have to buy the pump and sender unit together for $500!! Do 98's have different pumps or can I just replace the pump also? Can really use some help.
I believe any GM truck built with the Vortec engines (post 1996) has this kind of pump. Now, a GM dealer is going to tack on their premium as well. I'd recommend going to Advance Auto or Murray's or whatever and have them look up the pump for your truck. I'll bet it'll be about half that cost. Because GM redesigned their fuel pumps in 1996, the sending unit and pump assembly is considered an 'unservicable assembly' and must be replaced as a unit. They also made it so very few vehicles have interchangable fuel pumps as well. For example, my fiancee`'s '99 2-door Jimmy has a different fuel pump than my old '96 4-door Jimmy.
Both trucks have the same fuel pump, what happened was gm got rid off that fuel pump and now will only sell it as a fuel pump module assembly, you can still get the pump. click on link below. you can get it for $87 + shipping
used the part # you have posted here
GM PARTS
GM PARTS
Thanks alot for the information. I'm tempted to buy the pump at that price and just keep it on hand.
