4l60e question
tonyt915
ok found out i do have a 4l60e in the truck and also found somthinelse out is the tow/haul button supposed to dissengage o/d in the final gear? i was doing 60 and pushed it but nothing happened. i slowed to 50 and hit still nothing, but when i take off say around 30 it will work is this normal or is there something wrong or is this normal
Here's the official description and operation from our service information. Please show me where it says it locks out O/D.
Tow/Haul Mode
Applies to the following models:
• 2000-2004 C/K Utility Models
• 1999-2004 Chevrolet and GMC C/K Pickup Models (Silverado and Sierra)
• 1999-2002 GMC S/T Utility Models (Jimmy and Envoy-Old Style)
PURPOSE
• Reduce the frequency and improve the predictability of transmission shifts when pulling a heavy trailer or a large or heavy load. This is most apparent in city traffic. Without tow/haul, the transmission may upshift on a closed throttle decel. With tow/haul, the transmission will hold the current gear on a closed throttle decel. This reduces upshifts and downshifts.
• Provide the same solid shift feel when pulling a heavy trailer or a large or heavy load as when the vehicle is unloaded.
• Improve control of vehicle speed while requiring less throttle pedal activity when pulling a heavy trailer or a large or heavy load.
ACTIVATION
• Tow/Haul is selected or de-selected via a switch on the end of the transmission shift lever for all models except the GMC Jimmy and Envoy, their switch is mounted on the shift console. A light on the instrument panel will illuminate to indicate that tow/haul has been selected.
• Tow/Haul must be reselected every time the vehicle is started (if desired).
FUNCTION
• Tow/haul is designed to be most effective when the vehicle and trailer combined weight is at least 75% of the vehicle's Gross Combined Weight Rating (GCWR).
• Operation of tow/haul in a lightly loaded or non-loaded vehicle will not cause damage. However, there is no benefit to the selection of tow/haul when the vehicle is unloaded, this situation will cause a firm shift. The tow/haul switch is not a performance switch.
• Selection of tow/haul when unloaded may result in unpleasant engine and transmission driving characteristics and reduced fuel economy. Tow/haul is recommend only when pulling a heavy trailer or a large or heavy load.
• Examples of altered shift speeds when in tow/haul:
- Minimum 1-2 shifts pushed out approximately 13 km/h (8 mph)
- Minimum 2-3 shifts pushed out approximately 24 km/h (15 mph)
- Minimum 3-4 shifts pushed out approximately 48 km/h (30 mph)
- Tow/haul only affects shift points below 88 km/h (55 mph).
Refer to vehicle Owner's Manual for further information regarding tow/haul mode.
When I pull my boat with tow/haul, I have to get up to 65mph before overdrive kicks in...that's the reason I pretty much keep it in 3rd unless I have a nice long flat stretch of road.
No, Tow/Haul does not lock out O/D or any gear for that matter.  It just modifies the shift characteristics.
Hmmm...then my impression of it was wrong...Maybe it's just because the only thing I've ever driven w/a tow/haul mode was a Ford...and it DOES lock you out of O/D.
    HWN808
    HWN808
  • Who's Online   5 Members, 1 Anonymous, 561 Guests (See full list)
