2004 5.3L Silverado Losing Coolant
  • Replies 144
I added dexcool today, checked my oil and inspected the inside of the oil cap and filler neck. The inside of the cap had this brown rusty color build up. You can see it on 2 spots of this wipe. I won't be able to pull the vc's for a few weeks. Just bought another house and I'm moving. Good thing it has a 3rd stall for fun stuff like this.
2004 z71 bought brand new have the exact same things going on minus the smoke on startups. Mat be doing it and im just not catching it. About 2yrs ago noticed a small wet spot, investigated and found water pump gasket leaking., this was around 125k. Haven't pressure tested yet,but no signs or smell of coolant anywhere. Just changed oil today and found some disturbing sludge, it was alittle overdue but there was some chocolate syrup.that dripped out of the pan. Don’t.know what's up,and a mechanic IAM NOT. When I read the original post it was like I had written it. Your stepdad is not alone. If I stumble on a soluion I'll post it good luck.
  • 1 month later...
Mine is an '04 Sierra 1500 with 5.3 liter Vortec/ 4WD/ AT. Just coming up on 90,000 mi. Bought it used 1 yr ago. Outside of towing a 23 ft boat for approx. 60 flat miles four mos ago, I've been easy on her. Early on it's only problem was lifter noise for 10-15 sec on morning startup. Later,began experiencing gradual coolant loss (approx. 1 qt. every gas fill/ 250 miles)-now only slight coolant loss and no coolant odor since I threw in some liquid aluminum last week. Temp gauge staying good also but it never really would go up very noticeably. Also added 1 qt Rislone to my oil change (done 275 mi ago) and noticed oil level down about 1/2 qt yesterday - so I topped it off with more Rislone. Prior to the treatment I would lose at least a qt of oil every oil change depending on how hard I drove her. When I was having the oil changes done soon after I bought the truck the outflow was heavy with sludge and I took to using 89 octane and synthetic oil ever since.Have seen light puff of smoke only occasionally on startup and only after sitting overnight. Oil gauge reading all the way right pointing toward 4 o'clock as if broken- only moves slightly back on occassion or deceleration- it used to read between low end and medium in early months. Having no issues with power but getting some rattling on acceleration (0-25mph,especially if done quickly). So I was developing some concern about the rings but kinda glad that there weren't real bad crankcase problems yet.Was considering I would do a head/head gasket/rings job soon for a more permanent fix.I was honestly going to make my first entry to this website this morning to see if you guys liked my thought process but first I wanted to start her up and get fluid level checks.Well (and I swear this is the FIRST time) it starts rattling like there's you're shakin a large spray paint can. Still turning-no freeze up. Rattled louder with higher accel. but slightly less as it warmed up- I haven't dared get on the road since this started. Slight puff smoke at first but didn't continue.Dipstick clear and up to top level. No leaks underneath. Temp gauge good.The noise does seem to be coming from low in crankcase. WTF. Did I just happen to witness exactly when this thing went from having just moderately bad problems (gasket/rings) to all out disaster (rods/bearings/shaft) right as I'm looking under my hood? Did I F#$@ it up myself with these engine treatments? Is this what they do right before they break and freeze up? HELP!!
  • 1 month later...
OK it is 6: like I said I went buy what I had to use and was not sure.
Otherwise I can't explain the symtoms you have described. Start with testing for leaks in the cooling system and go from there for now.
Share your results, or any addition symptoms or info that you might find.
I'm having the same issue with my truck. I just bought this used and this is my first Truck. I am losing coolant every 200 to 300 miles. I pressure check it the engine and it stay pressurize for 1 hour. so I don't know what else to look at.
Pull the valve covers to find if you have the suspect head and problems. You could be leaking in other locations. Water pump and gaskets are the most common location. They may be hard to find too. They don't always pour water, just a small seep while the engine is hot will evaporate before hitting the ground. You can add a special dye to the coolant, then use a black light to find most leaks. Head gaskets can be another culprit
  • 3 months later...
I have a 2005 Sierra 1500 CK 4.8L. Bought the truck new and I am another owner whose dealer was eliminated. Truck only has 108,000km (just over 60,000 miles) and had all servicing. Just noticed in the last month problems with the heating system, thought I'd change the thermostat and saw coolant reservoir was nearly empty. Refilled twice. Can't see where coolant is leaking. Oil looks good. Going out to look at the truck and pull valve covers off and check for Castech logos and signs of leakage. I've owned four GM cars and this is my third and maybe last GMC truck. Had the first truck 15 years, second 12 years and had only normal maintenance repairs on these. My current truck has also had wheel bearing replacements, brake problems, tie rod replacement. and is showing rust in more than one location already - my 12 year old Sierra still had no rust when I traded it.
I've already spoken to GM about my dissatisfaction with the truck but they do not appear to care about service after the sale.
  • 3 weeks later...
I went through all of this back in june. My 04 sierra 5.3 had the castech issue, fixed it myself for 1500 with 2 brand new head castings from GM, then a shop swapped all of the internals over.
Also did lifters, water pump, hoses, all gaskets, etc.
It sucks but 1500 is better than paying for a new truck.
Any questions, just PM me. My elbow is still F'd from torquing the 30 head bolts in a row...
Mike
Mostly 5.3's came with the castech heads, a few 4.8's had them but very few. Most of you this is going to be your problem. You don't have to replace them with new heads. You can find heads online for around a $100. have a machine shop do a valve job and clean the surface and your ready to go. The 862 off of the 4.8's is nearly the same head just the combustion chamber is a little bigger (around 1cc) do to the 4.8's having flat top pistons and the 5.3's having dish pistons.
The tapping noise is usually piston slap. The LSx series are notorious for this. It only happens on start up, after the engine warms some and the internals swell and tight things up it stops. Another is the lifters do to the aluminum heads and composite intake there is nothing to to absorb the sound of the valve train like on and old iron 350 motor with iron heads and intake.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,458 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
