Tire size
littlemike754
  • 3 weeks later...
They should fit no problem......dealer should be able to reprogram to 265's for minimal $...it's amazing what a six pack can buy! ( at least at our dealership)
Hi littlemike754--265/70R16 are exactly the same diameter as 246/75R16, and about the same load rating, so they will fit without any modification required.--Frank S
You will lose about 3% of the torque at the rear wheels with the larger tires. Not significant, but if you tow heavy trailers, it will be noticeable on steep grades.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
