I've got the dreaded steering wheel issue I think
So at 9,000 miles my steering wheel is getting some vibration and knocking feeling coming through it. Especially when in a curve, you can feel some looseness or motion through the wheel. It's hard to explain, but you can tell that something just isn't right. I guess it's the dreaded steering shaft issue everyone has. Would that be correct?
So is this a huge problem? Should I have it serviced right away? Is it something I can lube up in the driveway to prevent a trip to the dealership?
Yes, buy the grease kit, follow the instructions, takes about 20 min.
It isn't a safety issue, in that it isn't going fall apart or anything. If you're in Warranty, which you must be, go to the dealer and they will lube the shaft for you.
Thanks. I will keep an eye on it and probably have it serviced after the holiday season is past. I just didn't want to wait if it was something dangerous.
Mine was done at 34,000 miles and it's doing it again at 38,000! :lurk:
:D
It wasn't done right then. I did mine, 90,000 miles later and all is still good. If it's done right the grease works great.
True. Some vehicles actually require two lube kits depending on how little lube was in it to start with. On such a vehicle, the problem will come back soon if only one kit is installed. I have done a few that required two. If the tech reads the instructions with the kit, it tells him how to determine if there is enough lube in the shaft when you are done.
:D
I have asked before but have not had time to investigate myself.... But can a grease zerk be taped into the shaft so that grease can be added while it is in the vehicle?
I was hoping there would be a zerk fitting already installed on there if GM relies on grease volume and pressure to take up the slop in poor tolerance parts. I guess I was being too optimistic.
I think the answer is yes - you could drill a small hole in appropriate location, tap the threads and install a grease fitting, but it better be done after basic warranty expiration. GM could use this as an excuse to deny the warranty coverage, as it would be considered "unauthorized modification". I have 5k miles on my truck, no problems in this area yet, but it certainly is not encouraging to see the same truck with 9k miles develop this problem alrady.
So to grease the intermediate shaft, you need tto remove the shaft first, right? And all of this takes only 20 minutes? Of course, this assumes you know exactly how to do it.l what is the part # for the grease kit?
i am hoping that GM has redesigned this shaft for the new style '07 model trucks. Is this part interchangeable with the one installed in our trucks? Will it solve the problem for good?
If you clicked on the link I provided and read the doc, you will see this::
Steering Column Intermediate Shaft Lube Kit GM p/n 26098419
Hope that helps. :lurk:
Mine was done at 34,000 miles and it's doing it again at 38,000! :chevy:
While I'm glad it's worked out in your case, we would need more examples to say that this is true in general. A number of owners have had multiple shafts replaced in addition to lubrications and the concern keeps coming back. I know an independent tech who checked mine out said that there is noticeable play in the steeing shaft as well. Additionally it may depend on the type of driving one does and the surfaces one travels over. If you are in an urban situation where the roads are rough and you do a lot of stop and go driving-the tech who lubed mine was able to reproduce the problem simply by taking off or backing up from a stop-you may experience it sooner. I'm thinking because those conditions are likely to result in more movement of the shaft and the lubricant is warn away more rapidly.
I noticed the problem prior to 6000 miles. :chevy:
20 minutes may be overly optimistic for a novice that has never done this before, but it really is easy. Easily less than an hour for a DIY'er. All you need to do is disconnect the 15mm bolt that connects the upper intermediate shaft to the lower intermediate shaft. This bolt is easily visible next to the exhaust manifold. On a Duramax I have found it easier to access this bolt through the wheel well, between the liner and the frame. Then disconnect the 15mm bolt that connects the upper intermediate shaft to the steering column. Then remove it.
I have found it easier to remove the shaft if you spend 2 extra minutes and remove the throttle pedal assy from the firewall, which is secure by two 10mm bolts.
Make sure you do not let the steering wheel spin freely once you disconnect the intermediate shaft. If it spins 360 degrees and you put it back together like that, or if it spins 180 degrees and you don't know which way it went, you will have a problem. Once you put it all back together the airbag clockspring will get "sprung". It is clocked to the column and will not like being turned one revolution farther than it is intended to go. Usually I remove the first bolt in the engine compartment. I turn the steering wheel 90 degrees from center to make the bolt face up for access. Then I turn the steering wheel back the OPPOSITE direction 180 degrees (90 degrees from center the other way). This will make the bolt under the dash face down for easy access. Then before I pull the intermediate shaft loose from the lower shaft and the column I turn the wheel to center again and run the seat belt through it and buckle it. There is actually a special tool to prevent the wheel from turning, but odds are you don't have it and the seat belt is easier anyway.
Once the shaft is out you just removed a clip from the end of the shaft, inject the grease using the provided syringe and place a rubber plug, also provided, into the shaft. Then you compress the shaft to disperse the grease throughout. Remove the plug, instert the aforementioned clip and re-install. This actual lubrication procedure will be shown on the instructions that come with the kit.
Reinstall the shaft, being careful to keep track of the steering wheel position.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
