Is this possible?!!?
Doogie
Ok so I was wondering if there was a way to make any type of GM nav unit work wtih any other type of truck.
I have a 06 GMC CC that has the base bose system. If I was to put a nav unit in that is not compatible with either the bose system or the base bose system coud I put a after market amp between the nav unit and speakers to make the system work?
Also how did you guys find somone who had any knowlege about doing this set up? Everyone I talk to doesnt want to help, says it cannot be done and suggest I get a new truck or somthing to that degree.
I really want a particular Nav unit in my truck the touch screen unit with the DVD drive behind the screen. I have not found one that is compatable with the base bose system and really dont know if they do make one with the dual drive that works for the base bose systems.
Thanks
Doogie :)
do you want a factory delhpi made nav in your truck? or aftermarket? if you want factory made type. i suggest the delphi tnr800. look it up. there are 4 different versions for four different types of gm vehicles. your 06 sierra should be compatible. i dont see why not. however. if you are unable to make this work for you, and stilll want to go abouts the route of the incompatible audio unit, then yes i do believe it can be done. you have to bypass your factory audio system entirerly by adding a 4 channel amp, running speaker wire from the head unit all the way to the amps. or you coupld tap the speaker wire into the bose amp if you can locate the input. then get a 4channel high output converter so you can run high frequency rca's from your head unit to your amp. thats pretty much it. its just like, and actually it is, as if you wanted to add amps to a factory radio that doesnt have rca outputs. now if you check out the tnr800 and it works for your year make and model, youll have bose audio, but if you decide to add amps in the future, youll still have to follow those steps. the tnr800 is an oem aftermarket made unit. well hope this helped/. good luck!
Ok so what are the 4 different types of TNR800? I really want the one that has the DVD drive behind the LCD. Where would I check out the different types and prices of the TNR800? Is there a website or do I ask the dealer?
Thanks
This is very possible. A company called PAC(pacific audio co.) makes adapters to install any aftermarket nav in that truck. To intergrate the Bose you need a OS2BOSE, and to intergrate steering wheel controls you need an SWI-X. The OS2 will plug right into your factory radio harness and give you connections for the new nav. It also keeps your Onstar in working order. The SWI-X is a little more complex to install but not terrible. Mtera makes an install kit to fit a double din nav in the dash, as well as an antenna adapter...
yes thank you mike. like mike said, if you want the dvd behind the screen then youll have to go aftermarket. the tnr is a nice unit if you dont want to lose factory installed options without adding adapters etc. my dad i installed the tnr800 for, he has the xm onstar, bose, and rear entertainment dvd monitor. in his case he would lose a lot. so i installed this one and bypassed the factory nav screen to accept dvd's on it. it looks clean and by itself is super easy to install. but the bypass is a little more complex. i on the other hand have an eclipse unit that has a 6.5in screen with dual drives. one for cd/mp3 and the other a dvd rom/ dvd player. the dvd rom is for dvd maps for navigation. but when you wanna watch a movie on it you have to remove the nav disc. therefore losing nav temporarily. im going to say this because eclipse's customer support blows. dont buy an eclipse because the system is slow!!!! i only bought this one because the price i got it for through work was like 50% off retail of 1800.00. if i was to spend the money id get the pioneer AVICZ1. 7" screen, hard drive for the navigation, and independant cd/dvd/mp3 slot. the hard drive allows nav in all and any modes of operation. also accepts either xm or sirius. oh and by the way, the siruis tuner from eclipse sounds like garbage. sounds like rf modulation. the avicz1 will run you just above 2 grand. if navs not all that for you, theres a cheaper one for a couple hundred less thats no nav, but has a built in 6 dvd changer. but i think its 6.5" screen, and i dont remember the model number. steering control like he said is possible, a little tricky, since youll have to program it and locate the steering control wire i think in the steering column next to the ignition. but works perfect. less the mute button which i havent figured out how to program yet. the data retention harness 0S2BOSE will run you about 100.00. just fyi. umm i think this all covers it. hope this helped.
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
