6L80 Transmission gearing
Would anyone have the inside scoop on gear availability and torque converter lockup with the 6L80 transmission. Specifically --
* In tow/haul mode, which gears are available?
4th at 1.15 ratio
5th at 0.85 ratio
6th at 0.67 ratio
* In tow/haul mode, which gears does the torque converter lock up on?
* In normal mode, which gears does the torque converter lock up on?
Thanks!
