Differential fluid change
For 2005 Yukon XL 1500, what is the rear differential fluid capacity and fill level. Is it level with the fill hole or about 1/2" below ?
Nowhere in the owner manual does it mention what the fill level or capacity is.
Also how about for the front differential ?
This is for my silverado but I assume it is similar?
Axle
Rear 8.6 Ring Gear 2.0 Liters 2.1 Quarts
Rear 9.5 Ring Gear 2.6 Liters 2.7 Quarts
Rear 10.5 Ring Gear 3.8 Liters 3.25 Quarts
Front 1.66 Liters 3.5 Pints
The rear diff should be about 10 - 40 mm below the fill plug. It takes a little more than 2 quarts, as you will notice in Ryan's post where it states 2.1 quarts. There should be a tag above the fill plug telling you how full to fill it and what kind of oil to use. You should be using synthentic oil.
To check the fluid level I use a 6" piece of wire from a coat hanger that I placed a 90 degree bend in. Then I measured 10mm from the bend on one side and marked it. Then I stick the marked end into the fill plug and measure the oil level.
Axle
my was way low when I did it. like a full qt. no damage done.
I'd venture to say a little lower is better than oil pouring out of the hole, like I usually do.
Axle
3.8 liters is about 4 quarts, not 3.25 quarts.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,089 Guests (See full list)
