Tailgate Lock
Yesterday I took the gate off to lube the hinges. I started thinking how easy it would be for someone to steal one while you are at work, shopping, etc. I know they have the Pop and Lock out there but I wonder if it could be jimmied with a prybar or something. Anybody have any experience with gate locks?
I have the pop-lock and it just prevents the handle from being lifted and actuating the tailgate releases. You can still see the linkage inside with this lock on. I don't know for sure if it can be opened, but doesn't look like the most secure option.
I kind of wish I checked out the Bully lock. It replaces the entire handle and may be more secure.
I remember seeing a few people who had the Bully lock listed in their signature so I'm sure someone could help.
Tailgate theft is very common and very easy to get away with.
I use the Gate Keeper, I also sell them :D
I prefer this over the locks that mount with the handle for two reasons. I open my tailgate many times a week, those locks would be more of a hinderance for me. Also, they are more easily defeated.
Here is some information in case anyone is interested:
http://www.trucktechniques.com/
So what the heck came in your kit? A allen wrench and a bolt????????
Or is there a bracket also???????
this is off topic but ill ask anyway. How are the locks in the winter.. everytime i have something lockable that is out in the cold the locks freeze up and i can never get in. (hence 2 tonneaus and 1 camper with this problem).. heck my old truck i installed electric door locks just so i wouldnt have to struggle with the keyhole in the early morning.
Has anyone ever had their tailgate stolen? I've personally never had an issue with it, nor have heard of any of my buddies having a problem. I spent 4 years in baltimore (where anything that's not bolted down is gone by morning) and never had a problem. The fine residents of 'Charm City' broke into or stole about everything else of mine, but I never had any tailgate issues.
Depending on the truck, our kit includes the bracket shown, the fastener and the wrench. It is a great deterrent.
I had something similar on my Nissan pickup. it was a bracket bolted on with a secure fastener that prevented the tailgate from being detached. the only disadvantage i see is that if the thief tired to remove you tailgate and got it hung up on one corner, they would probably damage it by trying to force it off or they would rop one end on the ground out of frustration.
A good visible tailgate lock seems like nicer and better deterrent. Why is Gm so cheap. Ford and Nissna have been installing standard tailgate locks on their truck for years now.
From what I can see, the bracket supplied is different from the stock one. It does not have the cut out to enable lifting off the pin. So unless the thief had the right allen wrench with him, neither side of the tailgate would come off it's respective pin. Right? I have heard of people who had their tailgate stolen, replacing it including paint and finihing is over $1000!
I have the tailgate lock from GM. Works very smoothly and looks good. I am sure a very determined thief could probably pry it, etc and maybe get it open - but I suspect they would in reality just move on to an easier target without the obvious lock. I think it was around $50 as I recall....
I have tried to yank off my tailgate, the bracket does not budge, it stays connected to both hinges, so neither end of the tailgate is going anywhere.
Any of these locks are deterrents, for some people (like me) who actually use their tailgates frequently, this model provides the least amount of hassle for the owner.
I strongly recommend any type of tailgate lock to help prevent theft :D
Get one of those little spray cans that you spray in the lock (they look like a small breath freshener spray). Just don't leave in in the glove box, make sure its somewhere you can get it when you need it.
The Gate Keeper is along the lines of something I tried to rig. I tried to put a small screw type hose clamp over the slotted hinge side to keep someone from being able to just lift it off. Unfortunately the bolt head on the clamp was too large to allow the gate to close. Unless the crook carries a allen wrench set with him, this should be a good deterrent. If he has tools, he could probably disable any lock.
That is it right there. If a thief wants your tailgate, he will get it. Most of these crimes are totally random, they want to drop the gate, remove the cables and be off with it within seconds. Any type of lock can prevent this for sure.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
