Dux-n-Dawgs Posted December 22, 2006 Posted December 22, 2006 I needed a way to lock my tailgate since I put this topper on my truck bed. I seen the Pop-n-Lock unit, but from the pictures it looked like some kinda add on deal. While at the Truck Accessory Store getting a new locking assembly for the ARE topper, my buddy notices a product made by 'Bully'. It's a lock assembly that mounts inside the tailgate and supplies a new bezil for the outside. I think it turned out pretty slick, myself. Thought I'd pass this along to the rest of you guys. I hope you can see the key hole under the handle, this was the best picture I could get the other night. Ofcoarse you not noticing it is the main reason I like it (other than keeping CRACKHEADS out).
fossil Posted December 23, 2006 Posted December 23, 2006 What holds the bezel in place in place? The OEM tailgate bezels are just held in by a clip...pretty easy to pull off.
foghorn23 Posted December 23, 2006 Posted December 23, 2006 What holds the bezel in place in place? The OEM tailgate bezels are just held in by a clip...pretty easy to pull off. <{POST_SNAPBACK}> The bezel itself does pop out, but the lock is secured by a screw from the inside of the tailgate. One of the OEM screws are removed and replaced by one in the Bully lock assembly. I've had mine for about two years. I realize is someone wants "in" bad enough they'll get in, but maybe this might slow them down or draw attention. Not a bad $20 investment. vroten
pm26 Posted December 23, 2006 Posted December 23, 2006 The good news is that the new style '07 models have a factory tailgate lock. I also saw one with a factory power sliding rear window, but it is the same version Dodge uses - a regular horizontal slider with a remote control switch on the dash. Not nearly as slick as Nissan Titan or Toyota Tundra's rear slider.
