Head light question
Those are your daytime running lights. It is EXTREMELY common for those bulbs to burn out. The bulbs just weren't designed to stay on all the time.
They will only come on when you put your truck in gear.
Another possibility is the fuse under the hood has been taken out (assuming you bought it used). It's listed as DRL fuse.
I have 50 k on my 03 and have never had a dlr burn out. Also, I have been running a 6 hi mod which keeps the dlrs on with the lo and hi beam head lights. So my DLR's get more than their share of time on.
Check your fuses and your relays. Normally they will only come on when the tranny is in gear and the parking break is off.
BTW, Nice looking truck.
Thanks.
I just tried running the truck, and lights didn't run.
I am a new driver, so could you point out where the DRL fuse is generally at?
To test DRL's apply hand brake, turn on ign. do not start on and put shifter in drive. Go out in front and check in front.
My DRLs go out if the e-brake is engaged.
To test, ignition on, truck in any gear except park. Either have someone look for you, block the wheels, or park in front of a reflective surface.
Sorry, I have done that already.
The only things left are the fuse and the bulbs.
Gotcha, just wanted to make sure you didn't try with the e-brake on.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
