Sirius Radio Install
zickefoj
Can anyone advise me on how to go about wiring my Sirius Sportster SP4 unit in direct for Power? I have everything else installed and hidden well, just that silly 12V power cord in the Cigarette Ligher hole.
Thanks,
Jeff
The easiest place to get accessory power is in the fuse box on the end of the dash board. There are 2 10mm bolts there that are great for ground, and if you look in the fuse box, the top row, there's a 25amp fuse directly over a relay. I believe it may be labeled "wipers". Just pull the fuse and use a fuse tap for power.
The Sirius unit is only powered by 5.7 volts, the power is reduced in the plug from 12v. to 5.7v. Do not remove the plug end from your unit and wire it into 12v. this will damage your unit. Instead install another cigarette lighter socket behind your dash out of sight, get your power from existing cig. lighter Got mine from Wally World for about $5.00
Hope this helps.
Hope this helps.
From reading the back of the unit I did catch that it was not 12 volts so I got a universal kit for $20 from Best Buy that reduces the volts on a hard wire from 12 to 5.7. My issue with using the exsisting cig connection behind the dash is that this is powered all the time and would still require me to power off my Sirius unit. This is what I am trying to avoid since I have already drained the battery once :driving:.
The specs on the kit I got is as follows for anyone else requiring the same info:
Universal Adjustable DC Adapter for 12V applications
works with Pioneer, Delphi, Audiovox, XM and Sirius satellite radios.
Part number is: RS-0001
the unit connects to 12V systems and then outputs a selectable range between 1.5 V and 12V.
The phone number on the package is 952-836-2311 and they are in St Louis Park, MN. The company is Hitchhiker Electronic Gear (Loon International LLC.)
Regards,
Jeff
Still using the fuse box to the left of the dash board as mentioned earlier you can find pins in there that only have power when the ignition switch it turned on. Use a light tester and go across the pins to see which ones have power constantly and which ones don't. Turn on your ignition and test them again. The ones that now have power is where you want to hook up this cigerate ligher assembly you have. Just remember to fuse the link between the pin and the cigerate lighter.
I can try to get a couple pictures of how I wired in a navigation system into my fuse box if you like.
Have a nice day.
Bill
there are time based features on sirius radio whereby they shut themselves down after a certain amount of time.. might want to enable that option.
Don't hook up to any fuse that could affect safety, like wipers, any head/tail lights. I usually go for the Radio, Dome, or other unimportant electrical component. Last thing I want to do is be driving and it start raining, and when I turn on the wipers it blows the fuse. Not that your system draws more than the fuse, you just never know.
Here are a couple pictures of where and how I wired into the left fuse box. They aren't the clearest pictures but they do give you an idea as to how you can wire in a constant hot or one that is hot when your ignition switch is on. Just use a circuit tester on each pin to find out when the power is there.
Have a nice day.
Bill
    • HM oils and cleaning. Well, soft deposits yes, perhaps. Like you say esters are present in in theory that should be a plus. But, is there enough? 🤔 The marker is the "Aniline Point" and it has to be pretty low to solve out baked on deposits. The softer sludge, yea, they do that and that is the claim. Valvoline R&P is the only HM oil I know of (Jury is out on Mobil 1's product) whose chemistry is uniquely able to remove the hard stuff and not be so aggressive as to swell seals to uselessness.    Oxidation levels in virgin oils blends is a good indicator of ester level and higher is generally a lower Aniline number and at one time we could predict without the $400 aniline test it's effectiveness. AN's, alkylated naphthalene doesn't show up in the oxidation test but does show in the aniline test and has become sort of a cheaper go to but most oils only add enough to solve the additive package. Not nearly enough to clean the harder carbon materials.   To your second question about does it matter. Yes is the short answer. Deposits are insulative. Those under the piston crown for example add octane requirement for knock free running. We don't' normally notice in todays motors due to Knock sensor driven ignition R-e-t-a-r-d. At least until the full slate of available values is consumed. Newer motors also often use oil jets to cool the piston to achieve tunes that would otherwise not be possible. Deposits on either side subtract from that. Deposits in fine screens used in VVT/VVL or DFM/AFM services live and die on cleanliness and screens are front and center. Vacuum pumps as well like brake booster in the K2's.    90% of todays oils are Group II+/III blends. A few more at PAO/AN/Group II's. A few boutique oils not Walmart shelf materials have enough solvency to prevent but not remove the hard stuff. R & P the current exception. Even HPL's EC30/40 used as directed (20% max) will get the soft stuff and some varnish out but not the hard stuff.    That orange varnish isn't baked on oil. Those are fuel varnishes left when the fuel diluted in the oil drops out when the oil cools. Like sugar does in a saturated mix of sugar and water that is put into the frig. That is ring sticking material and a glue the binds hard carbon sometimes.    Name brand shelf oils are intended to provide a useful service life at the least cost and highest benefit to the OEM who is trying very hard to keep you in $500 a month payment programs where the real money is made.   Did I miss anything you asked or left unsatisfied?
    • Yes, I understand. And I was saying (poorly), that it popped up on the DIC when I didn't have that info screen up. Just like you, but for a different maintenance issue. And just like yours mine didn't need to be shown at that time.
    • Ugh, amateurs.   But I did learn HM seal conditioners are esters.   I'm curious about deposit removal - some of the HM oils claim they really clean stuff up, the old and hard to reach stuff, and that's great? To Grumpy's point, a good oil should already be keeping the house pretty clean. I assume there are hard to reach places (underside of pistons?) and things that just accumulate baked-on oil and combustion vapors. If the deposits aren't friction or combustion surfaces and the deposit is just normal "seasoning", is it actually important to remove it?
    • You ask. The answer is yes. I think the strategy is brilliant. Or do you like more death and destruction? Gas is going down here. Maybe you need to change who you elect. Quit with the ridiculous statements or questions. You won’t get these answers.
    • Kicking off the weekend with $5.06 at the Kroger for 87. Are we great, yet?
