Heater Blower Motor Resistor
Changed the subject resistor in my 2002 Chevie Silverado...The purpose of this resistor is for speed control of the blower motor , in my case the blower would only work on #5 selection.......
There is a new modified resistor block to replace the original type..Cost in Canada was $58....plus tax from GM dealership...
The unit is located beside the heater blower , below glove compartment..Requires about 30 minutes to change for a slow old tech like me..
GO44
  • 4 weeks later...
Blower Motor Inop--Any help appreciated!
Hey from a newbie--I just replaced my blower motor resistor pack and the associated connector, both GM parts. The blower motor worked for 3 days and is out again. My initial problem was fan speed 5 went out (unusual if the electrical signal for '5' does not go through the pack) followed months later by speeds 1-4 going out. When I replaced the pack and connector, 1-4 worked, but speed 5 was still inop; and as stated, all inop three days later. If anyone knows what is going on, I'll take the help. Thanks
Blackchevy69
05' Silverado 1500 LT Crew
5.8L Factory Basic
Mods to follow (maybe)
  • 2 months later...
I have an 03 Sierra 1500 SLT Z-71 4wd. with a 5.3. I am having a problem with my blower fan, I'm not sure if it is the fan, or the climate controls. I have the digital Climate controls. The fan does not speed up when you increase it on the contoller. Sometimes it stays on low speed. Sometimes it stays on high speed. Sometimes, the fan will not shut off once you have turned off the vehicle. I have removed the fuse for the blower fan, because it can't staying on and killing my battery. I am not sure what the problem is, could it be that my resistor is bad, or is it something else?? Please help me!!
I have a similar problem with an '05 Sierra. Will work on all settings but 5, and sometimes not at all. REALLY sucked this winter, but at hwy speed, it warmed up.
I remember a few years back most GMs with A/C had a high speed
fan by-pass line (located on the firewall in the engine compartment).
It had a old style glass tube in line fuse.
I wonder if the new GMs have a seperate fuse for the high speed
fan circuit????????????..............geo
I found out that my truck doesn't have just the $15 resistor. It has a $98 module, it's the same as everyone else's resistor. But, instead of having a 7 prong input, mine has a 3 prong. I think it's because I have the automatic climate control, digital display. I am picking it up on sat. Hopefully that takes care of my problem.
Just an update. I finally picked up my module. It took care of the problem. Luckily I ran it through my Uncle's business account and got it for $73, versus the $98. But, still a alot more expensive than the typical resistor.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
