TJCamro Posted January 6, 2007 Posted January 6, 2007 When I try and put my truck into 4Hi or Lo or Auto Trac the light just flashes and eventually returns back to the solid light on the 2Hi. I can hear a click in the buttons when I push them but thats about it. Any ideas what the problem may be? I have a 2000 1500 Ext Cab with a 6 in lift.
2005 GMC SIERRA Posted January 6, 2007 Posted January 6, 2007 There was some sort of service notice on the switch that wasn't a full recall. I had a 2000 Chevy Z71 and mine did the same thing. Replace the switch and it will work fine. From what I recall, it wasn't too expensive to take it into the dealer. Good luck.
rjirvine Posted January 6, 2007 Posted January 6, 2007 I have read that the solder joints where the pins go into the circuit board on the switch assembly can be cracked/bad. You could take a look and maybe resolder them instead of having to buy a new switch.
Bish Posted January 6, 2007 Posted January 6, 2007 I have read that the solder joints where the pins go into the circuit board on the switch assembly can be cracked/bad. You could take a look and maybe resolder them instead of having to buy a new switch. <{POST_SNAPBACK}> Right on!. Even if you only have minimal soldering experience, it is an easy fix. All you really need to do is take the switch apart and apply the soldering iron to each joint to re-liquefy the solder and then remove. I found quite a few cold solder joints and they were easy to spot. Any solder with a really dull finish should be re-hit with the iron. I give a person with no soldering experience a 90% chance of fixing.
TJCamro Posted January 9, 2007 Author Posted January 9, 2007 So even if I hear an audble click coming from the buttons in the dash it might still be the connection? So where can I get the part to replace it online?
rjirvine Posted January 9, 2007 Posted January 9, 2007 Rockauto.com or ebay are good places to start. Were the solder connections bad?
TJCamro Posted January 10, 2007 Author Posted January 10, 2007 havent checked the connectons yet. I tried it today and heard the transfer case click in when I hit the buttons. Is it the acctuator foe the front axle that is bad then?
Bish Posted January 10, 2007 Posted January 10, 2007 havent checked the connectons yet. I tried it today and heard the transfer case click in when I hit the buttons. Is it the acctuator foe the front axle that is bad then? <{POST_SNAPBACK}> Until you check/fix the switch, you won't be able to tell. It could be either but given the massive number of problems with the switch, that would be my first fix.
TJCamro Posted January 29, 2007 Author Posted January 29, 2007 All right I just replaced the switch and it still flashes when i try and put it in 4wheel. I can hear the transfer case shifting but the lights still flash. What should i replace now? I am thinking the actuator.
HighSierraZ-71 Posted February 1, 2007 Posted February 1, 2007 When I try and put my truck into 4Hi or Lo or Auto Trac the light just flashes and eventually returns back to the solid light on the 2Hi. I can hear a click in the buttons when I push them but thats about it. Any ideas what the problem may be? I have a 2000 1500 Ext Cab with a 6 in lift. My 06 GMC Sierra did the same thing with 528 miles on it. The dealer fixed it, after reprogramming the switch, and changing the encoder motor, the culprit was a bad connection at the fuse block. Go figure. Now with 10K miles, no problems.
TJCamro Posted February 1, 2007 Author Posted February 1, 2007 not to sound like a noob but is the encoder motor the T-Case Motor on Rock Auto?
TJCamro Posted February 1, 2007 Author Posted February 1, 2007 i noticed that when I hit the button to 4hi it almost sounds like the t-case motor doesnt shift very far and it doesnt clunk into place like it does in 4lo. So am I in need of a motor and front acctuator?
