DC outlet control in 06' Sierra
I have a 06' Sierra with the (2) Auxillary DC outlets below the climate control. Both stay on all of the time. THis is a royal pain for using a Nav System, Radar Detector or I-pod as it will kill the battery. However, I DO like having an 'always hot' outlet for cell phone charging. Therefore, my question is how would you go about making one outlet an "always hot or on" and the other one "hot only when the vehicle is on"??
I pulled the dash and see they are both split off of the same wires coming out of the firewall, so I'm not sure. :)
Thanks for any help in advance!
  • 4 months later...
you could cut the hot wire from one and then run a new wire that is switched power to it. not sure if this would work for sure but its an idea
  • 2 months later...
Good luck finding one that is switched. I know there has to be some but I'm having a heck of a time finding one. Even at the interior fuse boxes every location is hot with my 2007 GMC turned off.
I pulled the dash and see they are both split off of the same wires coming out of the firewall, so I'm not sure. confused.gif
You could run a switched power from your fuse box if you wish. I did this for a direct wire on my radar. Just take a 12 volt test light and test the fuses in your fuse box, key on/key off, and you will find one that will stay lit or come on with the ignition. The easiest thing to do from here would be to get a fuse tap from your local auto parts store and attach a wire to it. Take that wire and replace it with the hot wire hooked up to your power outlet.
Now that you mention it, I might do this same thing. Having one outlet constant and one switched isn't a bad idea at all.
  • 3 weeks later...
Is there really a problem of an Ipod draining a battery? I have left my Sirius radio on in my car for 5 straight days. Driving a little each day and my battery has never shown signs of dying.
  • 4 weeks later...
Iam having the same problem trying to find a switched wire. I might try to go off of the climate control wires...there has to be a switched one there for my radar detector and sirius...I hope
  • 3 weeks later...
Don't just cut the wire and run it to just any switched source, use a relay! By doing that, the switched source will only be used to "trigger" the relay, you'll still be pulling power from the cigarette lighter circuit.
Cut the wire running to the cigarette light, hook the end coming from the firewall to 87 and the cigarette lighter end to 30. The ground 86 and tap 85 into the switched power source.
I 100% agree with thunderstruck
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
