Do my angles look alright???????????
Just wondering what you guys think of the angles on the front of my pickup. I have the Phord keys and crankied Tbars. The front sits 1/4 inch below the back. thanks.
6 people and no comments, anyone have a clue on what in exterme angles for the front. If they are to bad I will drop them because I plan on running this Pickup until it dies and.
Your bed might dance around a bit like that, but I dunno it looks fine to me. You should add a rear sway bar.
if you plan on running the truck til it dies i would put it back the way its supposed to be. having the tbars cranked will cause more wear then not having them cranked
They look fine, I've seen FARRR worse. My 00 sierra was cranked about that much at around 80,000 miles and it's got nearly 200,000miles the only problem we've had is a wheel bearing. But that was probably more due to how bad the truck was tortured.
mine look identical to that, i did the adjustment at 50k miles, am at 121k now without issues.
Nice looking pickup, thanks for the reply. I did mine around 14,000 and I now have 30,000.
Angles look fine...
Did you do an alignment yet? Some say you don't need too, I would say you do.
Steve
Yes I had an aligment done the same day I add the keys and have one since with nothing wrong. thanks for the reply.
