Looking to buy a 4wheeler
mmayo
I'm looking to get myself a 4wheeler & would like some honest opinions. For the past few months I've had my fathers 600 Grizzly (98 yr model i think) it has a little over 2000 miles & runs great. They also have a Kodiak. I am looking at either the new Grizzly 700 that just came out or a polaris sportsman 800. I really like the size of the sportsman better than the yamaha(the seat especially since I am 6'7"). It is MUCH bigger than the yamaha & my son could fit on there much more comfortably riding w/ me. Since I have experience with the yamahas I know they are really reliable & I haven't heard a lot of good things about the polaris sportsman first hand. There is a group of guys that ride near my house & one had very bad luck w/ an '05 sportsman that the dealership finally ended up buying back from him for what he paid for it. The group told me that there is much more maintenance on a polaris than any of the other major brands that have been around.
That said, for those of yall that have or have had polaris sportsman’s how would you rate them? I dont want to sacrifice quality for size of the seat or spend that much $$$ on something that will just break down on me.
Thanks
-Mayo
I have a Honda Recon and it's held up pretty well.
go with the yamaha. My dad had a sportsman, and it was ok, ride was ruff and the suspension was way too stiff, motor a little slow on the uptake, etc. He traded it in for a grizzly and a kawasaki brute, and man those things have power. Both of them will about throw you off when you mash the gas. the brute has a little more power with the grizzly being the faster of the two ( I think the brute has a bigger engine, but the grizzly weighs less). Both ride really well, fit in the bed of a pickup, and look pretty good clean or covered in mud.
I have one too. I have put it thru hell and still runs like a champ. :) I am a believer in the Honda's
My Recon is far from Bling Bling, but it is an overall good 4-wheeler. My cousin has a Rancher that I can assure you was dogged as much as humanly possible, it still runs pretty good.
I agree with carneyman, go with the Yamaha.
Take a look at Kawasaki too. They kick some serious ass, I have a 1998 Bayou 300 that I must've took through hell several times, and it still comes back for more. If you could only have seen the beating my uncle's 1997 Bayou 220 took, it's amazing the engine never grenaded or seized up, let alone start up first time every time (it doesn't idle good anymore though).
I have a Kaw, but to answer your question, I would go with the Griz. The Polaris machines have grease fittings, and lots of them!! I have friends with three of them, if you like to you use your grease gun all of the time I guess it's ok. It takes about 2 hrs to change oil and grease everything, big pain IMHO. If you do lots of reverse wheelies and weigh over 275 pounds, the Griz will eat up front wheel bearings, don't ask how I know.
The main reason I was leaning Sportsman was the size.......I'm 6'7" & weigh 240........
The Polaris RZR does look awesome! I read up on it a few weeks ago when polaris introduced it. I may not fit in it though!
I driven rangers 4x4s & 6x6s & they never cease to amaze me.
Polaris.
But that's because I had one.
As to their grease fittings, I'm an overly anal retentive former mechanic who is obsessed with preventative maintance. In the several years I owned mine, I can count on one hand how often I snapped the 'ol grease gun onto the Zerk fittings.
And mind you, I had mine buried in mud or blowing through snow (drifts) most of the time!
Now see, I had mine tuned by a member of Polaris's snowmobile racing team. When I left it in two wheel drive, slammed the throttle open, I could pull the front wheels off the ground! That was on a stock motor too! Nothing more than a proper tune. This was an ATV that would weigh in in excess of 700 pounds with me on it!
Yamaha and Polaris are both reliable in my experience. Had about 4 of each brand so far.
Can-AM 800 is the king of go-fast utilities.
Yamaha has the easiest maintenance IMO.
Polaris Sportsman the best suspension. Ride all day without getting tired. I've not had any reliability issues with any of the above.
Sportsmen were crap back in the 90's but the newer ones are fine.
DT
    • I would argue that GMPartsDirect has that info wrong.    The service manual for R+R the lower arm and for adjusting camber/caster, none of the steps say to discard and replace the nut or the bolt.    The only part that gets discarded is the plastic cam adjustment retainer that is in the eccentric from the factory.     The LCA nut torque spec is: First Pass: 180 Y (133 lb ft) Final Pass: 90 –105 Degrees
    • The filtering to wear relationship goes like this:      'Relative Engine Life "Factor" new divided by the factor old. So 8/3= 2.67. That result is the multiplier thus if a motor had an effective life of 100K using a filter with a 45 micron rating at a Beta ratio of 75 then a filter with a micron rating of 10 at a Beta of 75 would improve expected engine life to 267,000 miles.    Wear metals are an indirect indicator. Less is better and the motor lives longer but there isn't a multiplier like there is for filtration so well documented. Most of that has to do with the sensitivity of the wear metals tests themselves. They read a 'slice' of the spectrum but not the absolute values for the entire spectrum. So a general indicator that is used WITH the results of other tests. Two others considered in this post. Trending is very important.    There is also the influence of corrosive wear which may be seen in the wear metals but separate from load based or viscosity mitigated indication. It's a small graph but the gray line is wear vs the TBN/TAN crossover. Not as useful as it used to be as there are now new chemistries for acid remediation that don't show up in standard UAO testing. They will catch up or be found liars. Only two possible outcomes, eh?
    • One thing that comes up over and over is that the torque converters are the weak link. Many of the failed transmissions have the same thing in common. The torque converter grenades and then metal torque converter shards end up destroying the transmission. One of the best things you can do is if your transmission is still fully functional, change out to one of the aftermarket billet torque converters. There are several good choices mentioned in different threads here to make your choice. After that, then you can decide about trans tuning. My trans failed at around 95,000 miles. It got replaced under the GM protection plan. The remanufactured trans comes with a 100,000 mile /3 year warranty. I still have just under 1 year left. So far, so good. As long as it's still working good next year, an aftermarket torque converter is going to get installed early spring. If the trans and OEM torque converter fail by then, I will get it replaced under warranty and immediately have an aftermarket torque converter installed. A warranty replacement trans of a replacement trans will no longer have the warranty so I will bulletproof it from the get go.
    • You got'a be cooking right now. Just looked at the weather map. Yuck!    We are right back to $4 today.
    • Pushing $4.00 a gallon in most places, still $3.75 in town but it's going to spike tomorrow for sure.   Diesel back up to $4.60-5.00.
