jor Posted February 20, 2007 Posted February 20, 2007 87 5.7L TBI Suburban 4WD Well, this is my first post to this board. I usually work on my Ford trucks but I recently picked up an 87 Suburban. I am really unfamiliar with these engines and I am looking for some very basic information. I did a compression check on it and all the cylinders are between 160 & 170. Now I want to check the ignition timing but I'll be darned if I can find the EST bypass wire. I have the shop manual and it indicates that On the V6 and V8 engines, the system will go into Bypass Mode by disconnecting the timing connector. This is a single wire sealed connector that has a tan with black stripe lead. On the 4.3L and V8 engine, this connector breaks out of the engine wiring harness conduit adjacent to the distributor. I sure can't find that &*&@! wire!!! Here's a few photos I took of the area in which I am looking. BTW, I went through the FAQs (pretty impressive!) and did some searching but apparently, this question is so fundamental that no one has ever asked! Anyhow, I sure could use some help on this. Thanks. jor http://i102.photobucket.com/albums/m105/jo...omponents-6.jpg http://i102.photobucket.com/albums/m105/jo...omponents-5.jpg http://i102.photobucket.com/albums/m105/jo...omponents-7.jpg
billcar9999 Posted February 21, 2007 Posted February 21, 2007 I'm going from memory. I think it's on the passenger side firewall by the relays under the hood. I think there is a cover you have to remove to get to it.
jor Posted February 21, 2007 Author Posted February 21, 2007 I'm going from memory. I think it's on the passenger side firewall by the relays under the hood. I think there is a cover you have to remove to get to it. Hmmmm... the shop manual says that's where it is on the 2.8L engine but I'll take a look tomorrow where you suggest. Thanks. jor
jor Posted February 21, 2007 Author Posted February 21, 2007 I'm going from memory. I think it's on the passenger side firewall by the relays under the hood. I think there is a cover you have to remove to get to it. Hmmmm... the shop manual says that's where it is on the 2.8L engine but I'll take a look tomorrow where you suggest. Thanks. jor Turned out it was on the driver's side, just under the brake booster. It was taped up under the loom so I missed it. Anyhow, I got it timed now so that's a step in the right direction. jor
