Mods available for GMT900?
I love my new truck, but I want to add a little more power. Are there any companies making intakes, chips/reprograms, exhausts for the new trucks yet?
GM Performance offers headers, and a cat-back. That's all I've found so far. As far as programmers? I'd think you'd have to wait until summer/fall, but that's pure speculation.
Let me know if you find out anything.
I read about wait4meperformance.com on this site. I think that's the route I'm gonna go. I emailed Jesse about the GMT900, he has yet to respond.
There wont be much stuff out for the GMT900 since it just came out in November but give the venders time. Jesse and other tuners my not have cracked the code to modify programming the new trucks since its all new technology. GMT800 had a PCM & GMT900 has a ECM & a TCM.
  • 1 month later...
Corsa offers a couple of different cat backs. part#14199 is the sport and 14194 is touring
This is a dual under the bumper outlet
I ordered mine this am and cant wait for it to arive!
GMPP also offers a CAI, wehich i have installed on my 07 vmax and am happy with :)
I just added the GM Performance Parts cold-air intake system and a CORSA "Sport" exhaust system,Part#14259 (This is the "side-swept" outlet system) On my '07 6-liter and love them both.
Just bought an '07 Sierra 4x4 today. After almost 4 years with a Dodge Hemi, I'm going to miss the thrust, but I won't miss the cheap build. Just ordered the Corsa 14259 tonight. Hopefully that will wake things up a bit.
Hey guys, what the part number for the GMPP cold air intake?
17800809
Im pretty sure you can now order single or dual loud (cat back) exhaust right from the factory, and maybe aCAI too
I don't think so. Those are aftermarket products, and GM likes to keep the accounting issues separate.
They are a dealer add on, but yes you can order when you order the truck so they can be put on when you pick it up :)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
