Window switch internal lighting
Dans Denali
The internal lighting for the window switches in the drivers door on my 2002 Sierra Denali doesn’t work, is it a simple bulb replacement job? Another dark area is the bottom row of the heat/AC panel, how are these bulbs replaced?
Thanks for the help,
Dan
Nobody has ever had this problem?
Dan
This are LED bulbs and are not serviceable,time for a new swicth from the dealer.
Yikes! Ok thanks for the info, looks like they are going to stay dark.
Dan
Dan
Radio Shack has the bulbs. There were a number of them burned out when I purchased my '01 Xl.
It is a very delicate procedure, they are soldered onto pc boards. If your good at that sort of stuff then your good to go. Open up one switch and take it to the store for comparison.
Dan
My HVAC bulbs were out as well and I replaced them with Blue LEDs. Was a PITA but looks pretty good now.
  • 4 months later...
if you know how to solter and u can find a little tiny led bulb you can replace them, other than that you'll have to live with it :flag: or buy a new switch :banghead::banghead: , mine went out in my grand prix gtp, and i took the switches apart, and chuckled to myself and then just put them back togheter!!! stinks!!!
steve :driving:
  • 5 months later...
I've got the switch to my 01 crewcab apart. I'm at the bulb, but can't figure how to get the circuit board off the black plastic housing, so I can get to the back of the board, to de-solder burnt out bulb and solder on new one.
Any help?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
