cab lights
I know there are millions of posts relating to roof cab lights.....The new 900 style cab lights appear to have changed a little (look tinted and look LED)....I think these lights will look great on a black truck and I want to get a set for mine.....Can anyone tell me if GM offers these new lights from the parts counter yet?
Thanks in advance
anyone?????
Track down MS3DALE. He's a GM parts guy and can probably answer your question.
  • 1 month later...
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
