Regearing my rear-end
Has anyone experienced DIY regearing your rear-end on a NBS, specifically '02 or roughly '99 and newer? What headaches would this cause...would it void any warranty or are special tools required? I'd like to swap in some 4.88's w/ a locker.
It could potentially void your entire drivetrain warranty, cost a pretty penny (you have to do the front too) and requires quite a bit of labor and a couple of special tools.
2wd so I dont need to do the front. My warranty is getting close to being up anyways, so has anyone done this on a NBS and can give me an idea what to expect? Maybe let me know what specialty tools?
It's a 2wd? Cool! Now you can just find somebody selling an entire rear end with the gears you want already in it.
Swap it in...Should only take a few hours and some simple hand tools (impact stuff would make it easier though).
That would be a TON easier (and cheaper) than actually cracking the housing open and regearing it.
  • 3 weeks later...
My advise - purchase the Shop Manual! No, Not Haynes or that stuff (junk). Any tools will be listed by part number and you can purchase them online. The best part is the orginal Shop Manual will tell you about any short-cuts and the possible problem you need to be looking out for during the job. I have spent the last 6 years restoring a number of GM trucks and I never start the task without the Shop Manual in hand. Best of all if you ever sell the truck it is a great selling tool that almost any buyer will love to have in hand.
  • 2 months later...
If you attempt it yourself you'll need a press and bearing spliter, along with a shim assortment, rounout indicator...
Novices best way is to buy 2 sets of new bearings, hone the center of one set out so it fits the carrier/ pinion w/o pressing it on. Set your shims/ pinion depth with the "loose brgs. Once your happy with the way the marking compound/ everything looks, have the "tight" bearings pressed on, throw it back together, double check, and away you go :crackup: .
My advice: Call arround to some driveline shops, Get quotes on if you pull the axle and bring it in (Most places that do it everyday love it, as it doesn't tie up a mechanics bay, and knock some labor off).
Or a junkyark axle swap, is also an option, although it is a gamble. I don't think GM made 1/2 ton axles with 4.88 gears. 1 ton axles, maybe...
If ur not concerned about money.. or want some really good stuff.. i would recommend checking out dynatrac... ive got there 60 series underneath my 99... its got 4.88 gears with a detroit locker.. unit costs about $5500. But if u just want it for street use and a lil off road.. a gear swap or GM rearend would work just fine. A note on the locker... sometimes is jerky when u go first accelerate.. and when turning.. its almost like a posi.. it gives some..but acts alot like a posi.. and the tires will tear up a yard when turning...lol.. but when it comes to goin thorugh mud.. alot of times i dont even gotta lock it in 4wd.. just cause of the locker.
Novices best way is to buy 2 sets of new bearings, hone the center of one set out so it fits the carrier/ pinion w/o pressing it on. Set your shims/ pinion depth with the "loose brgs. Once your happy with the way the marking compound/ everything looks, have the "tight" bearings pressed on, throw it back together, double check, and away you go :happysad: .
This is really good advice. It truly is not hard to do, alot of people get intimidated by it. Its a 2 hour job on the rear end. IFS fronts are another story......
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
