Airbag Interchange Question
Boomer73
Does anyone know if an '05 airbag will fit on an '03? They look to be identical with the exception of the badge on the cover. Reason I ask is that I'm doing the steering wheel upgrade and figured while I was at it I might consider replacing the airbag too.
The air bags are the same, but yoou need to make sure that you are using the same stage air bags. Some truck were equipped with dual stage and others had single stage.
