Changing Stock Radio
I am getting ready to change out that stock junker radio and put in a Sony CDX-GT81UW. What will that do to the OnStar garbage that is in there?
Onstar wont work anymore unless you get an interface kit for it.
So the stock Delphi radio is junk and the Sony is quality? :rolleyes: Thats a good one. Sony car audio has been bottom of the barrel for a long time.
If your going to go as far as saying the Delphi is crap at least replace it with a good radio like a Alpine or Eclipse.
take some pics please of how you get the radio out. I have to pull mine in order to install my loc converters for my subs. Like the other guy said aftermarket radios/speakers aren't as good as most would lead you to think imo. I think it's just a bunch of propoganda to get kids to spend money they don't need to be spending. subs on the other hand make a much more noticable difference.
Yup JUNK. I find Sony beats that mess hands down. I've always used Sony and always will. GM stock radios aren't worth my fooling with.
If you think Onstar is junk then why do you care if it's going to affect it? I changed out the stock radio in my 02 and didn't worry about hooking the Onstar back up. It won't hurt a thing....
I agree go with apline, eclipse, or pioneer better equipment imo.
I think that 10 years ago changing your stock system to an aftermarket made a world a difference, however every year there coming out with better sound just with the stock system. For the amount of money it costs the difference won't be that big. However if you got the cash aftermarket will be the best. Imo though if you go with the slt or ltz the sound quality is great and not worth upgrading. The nicest thing about the aftermarket deck is how much more adjustments you can do over the stock system. And the other bonus's were the mp3 capability but the 07s have that as well. Expecially if you get subs too so you can fine tune the bass. And don't forget if you change it i could be wrong but pretty sure you'll lose your six disk changer if you have it as well as probably the ipod input. And yeah like others said you'll lose your onstar as well....good luck with it get some pics up when your done.
I disagree about the sound difference. I'm proof that good aftermarket equipment is far superior to what came in the truck from the factory. I could care less about the onstar equipment, I've never subscribed to it and I've never used it. If it wouldn't have been part of the LT package I wouldn't even have it. As far as hooking up an Ipod to an aftermarket head unit that's easily done w/ most of the good ones on the market and if you care to drop a few more bucks you can even get the bluetooth models at fairly decent prices. Everyone knows that those paper speakers are crappola as well. If you're not worried about keeping onstar functional then just don't hook it back up....it's easy to do.
I was just refering to the newer models. As far as the 00-05s the sound quality was poor, but listen to a 07 slt its actually not bad for a stock system but thats jmo.....
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
