1-2 Shift 2007 Classic
question for those with an 07 classic. just picked one up with 4:10's. does anyone think going from first to second seems to lag. it doesnt seem to want to shift then when it does sometimes the truck shudders. i did test drive 3 others all with 4:10's and shifted the same way. sure doesnt shift like my 02! kinda driving me nuts.....does seem to smooth out a bit once warmed up.
I've got an '07 classic with 3.42s. Same thing, between 1 and 2 the transmission seems to hestitate a bit, with the shudder sometimes. Seems to happen when the trans is colder (especially when it's in the single digits outside), particularly under light acceleration. At first it was a bit annoying, but I'm noticing it less and less now (getting used to it I guess, either that or its because the outside temps are warming up now, in the 70s today, can you say heat wave!).
I get the same thing when I have it in stock form. I also have 4.10's. Superchips took care of that issue. I know what you mean about the shudder. It does not inspire ANY confidence when shifting from 1-2.
My 03 Denali has the same horrible 1-2 upshift. I maxed the line pressure and quickness of the shift with my handheld tuner and it still shifts slow and sloppy. Anyone done anything that made this better? The 2-3 shift is great...
Thanks
Brian
Torque Management was the first thing that I shut off with the tuner.
Torque management is how GM (and others) keep you from abusing the drivetrain. Stomp your truck to the floor from a dead stop and notice the hesitation when you do it. The computer is limiting the acceleration and thus the torque transmitted to the driveline.
Any other suggestions??? I see that some people installed a shift kit in the trans. My programmer specifically says not to mess with the line pressure etc. if you have installed a kit in the tranny. I know the manufacturers think that the public wants nice pretty seamless shifts when they drive. But it would be nice to get a performance shift if you ask for it with the programmer.
Brian
