New First Time Chevy Owner Here
ws6_guy
Hello, my name is Darren & I live in north P.A. I bought my first Chevy on April 17th, a 2005 Silverado 2500HD Crewcab 4x4 with the 6.0L V8. I love this truck so far its great. It has 24k miles on it and it came with nerf bars, & a rhino spray in bedliner. Before this truck I drove a 2001 Ford F150 Supercrew, I loved that truck alot, unfortunatly Sunday April 15th it was stolen & totalled. idk who would steal it I mean it was only lightly modded lol. But i'm happy this has Onstar atleast, I got a very good deal on this truck, my fathers friend was selling it for $26,000, I got it for $15,000, I told the seller about my F150 being stolen, so that must have been a sympothy discount :thumbs: I am very happy with this truck and I cannot wait to start modding.
So far the mod list is as follows..
20% tint
Billet Grills ( upper only no bumper grills )
black bowtie emblem maybe
I would like to find black background headlamps, or buy one of those headlamp lense tinting kits off ebay & try it, just something to make the lights a little darker
4" - 6" suspension lift
not sure about wheels yet, I really like the stock ones on it though, but maybe black or chrome boggers.
I'm very new to the 4x4 world so I dont know too much about what to do wheel & tire wise lol, my F150 was street. I'm open for any input or suggestions anybody has for me, thanks :ughdance:
link to pics of my truck
http://www.rankmyride.com/?page=cars/view&CID=11274
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
