Adding Nav To A Nbs '07 Silverado
I was wondering what is needed besides the unit, to change the standard CD player to a Nav in a NBS sivlerado.
Any input would be appreciated.
Depends. Are you looking to go to an after market nav unit or just the factory nav unit out of an NBS?
Daddy
I am looking to put in a Factory unit. I was wondering if there was any other parts needed ie antenna ect.
mini1 is right unless you want to buy a used one from eBay at which point you should probably check with your local service department to see what else is needed. IMO, I'd go for an after market model considering the money you are going to have to drop on a factory unit anyway. Plus, you'll get better sound out of an after market unit.
Let us know what route you go.
Daddy
I believe that the factory nav system ties into the GPS system used by OnStar. There are several aftermarket GPS units - from TomTom to Garmin's Trip Pilot series. I tried a Garmin unit in a rental last week - and it worked well. We got off course several times and it got us back on track quickly. I went online and found that the MSRP on these units ran between 300 and 1000.00 depending on features - I suspect that the rental was a lower end model as it sometimes lost signal when in the city with tall buildings all around. I noticed that one of the specs was sensitivity.
Another option would be to opt for the Directions and Connections plan with OnStar. This not only provides you turn by turn directions, but the ability to make reservations and get travel help from the road - it is about $15.00/mo and the directions are loaded into your truck computer and directions come from the radio speakers. You can also contact a real person for help if you get lost - the system also can re-calculate the route if you get off track.
It is probably cost prohibitive to buy and install the nav radio in an existing truck - considering it is a 1700 option - I would start wtih the parts department and try to get them to show you the exploded diagram for both the std and nav radio dashboards. That way you can easily see if there are any special cables etc that you might also have to buy.
You just need to get the OEM parts, and bingo, all plugs in and works. JP Customs has been selling the parts as "kits" for years, and are by far the easiest to do and all brand new:
Without rear DVD system:
http://www.jpcustoms.com/store/customer/pr...=359&page=1
With rear DVD system:
I know people that have just ordered them from him, and all was done quickly and is as OEM as it gets.
  • 2 months later...
Anyone know if there is any truth to the fact that you can only add the factory nav unit to a truck equipped with the bose speaker system? I was told that the factory nav unit has no amplifier and you need the bose amp in order to have sound.
I have a 2007 extended cab (no rear seat DVD) and the 6 disc Bose stereo. Does anybody know if it's possible to install one of the two factory nav head units that would allow a DVD to be played on the head unit screen? I've seen that there is a lockpick module being marketed by coastaletech that allows dvd playback over ride, but I'm not sure if both head units have the capability of dvd playback, or if the one stated for rear seat entertainment can be installed in a truck without the option. Anybody?
JP Customs is a great toy store. Shop there myself. Last purchase was a Pioneer AVIC D2 Nav system, with all the needed adapters. (face plate, onstar lan data bus interface, steering wheel control interface)
There is something to be said for stock, but IMO (and experience) the aftermarket NAV radio's are the class of the field. The GM radio's are over priced, feature starved, and limit what you can and can't do without the vehicle in park. The NAV functions on the AVIC are top notch and most important the audio sound puts the OE head units to shame, both in bose and non-bose systems.
  • 3 weeks later...
You need a Bose radio (when you bought it) to install a factory Nav system. In addition to that, you need a factory nav antenna, wiring adapter plug, and programming done by the dealer for the radio.
Aftermarket is not easy task either. If you plan to keep your Onstar, you need to to pick up a bypass module from PAC. If your aftermarket radio has steering wheel control option, you need another module to do that and they are not cheap.
I have been thinking about this since I got my NBS. I wish there was a Non-Bose factory Nav and my decision would be made.
Jd
    HWN808
    HWN808
  • Who's Online   4 Members, 0 Anonymous, 1,002 Guests (See full list)
    • https://www.gm-trucks.com/why-gm-chose-0w-30-gen-6-v8-oil/   The swing back to reality continues…
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
