Fog Light Bulb Question
I have the factory fog lights and was wondering what the highest wattage bulb you can run (Silverstars preferably) in the housings whtout melting the lens.
Does anyone know the wattage for the factory bulbs?
Thanks,
The stock ones should be 880s that are 27watts. I put in Silverstar 893STs that are 38 watts and no problems. They are much bright than the stock bulbs. I think they make even a higher watt bulb that will fit too, but I didn't want to jack up the wattage too much. I use PIAAs for my highs & lows, but its easier to get Silverstars from the local parts store instead of mail order.
Thanks for the info. Now that I know the wattage capacity (and part#) I can go buy the Silverstars.
I also have the 38's, in a Silverstar as a matter of fact. No issues. I have heard of others with higher watt bulbs having melting problems.
I've been running the Silverstars for six months now (about 10,o000 miles) and I usually turn on my fogs while driving. No problems at all.
  • 1 month later...
On my old 04 colorado i couldn't find the right bulbs for the fog lights so I managed to fit Streetglow 9006 80 watt bulbs. I also had Streetglow's 80 watt in my high and low beams, everyone and their mother would flash their brights at me. I adjusted the hight of my headlights and had 18-wheelers flash me. I had that truck for 2 yrs and never had one problem. The only problem i had was slack in the driveshaft's u-joint from to much power-braking.
  • 1 month later...
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,692 Guests (See full list)
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
