20' Nbs 2007 Wheels/tires
I have a nbs 07 silverado with the Z71 wheels and tires and I really want some bigger wheels. My question is can I add the factory 20' wheels to my current tires or will I have to buy the new tires to go along with them. I also wanted to see if you guys thought it would look weird with 20' wheels on non-offroading tires with the raised Z71 package. I just wanted your guys' opinions!
If you want bigger wheels and are looking at 20s, then you must have either the standard 17s or the optional 18s, currently. Either way, if you want to go with 20s, yes, you will need new tires. If you buy the wheels from the dealer, it will be quite expensive. I've seen sets posted here recently, so you may want to keep an eye out.
I looked into the GM Accessories' 20" chrome wheel and tire package for my '07. With tires, lug nuts, center caps, pressure monitors, valve stems, mounting, balancing, and setup with the tire monitoring system, I was looking at almost $3,000. Decided to stay with my current setup.
As far as looks go, the 20s look good, better than 17s.
There are actually plenty of options for A/T tires that'll go on 20' rims. I recommend the Michelin LTX M/S in 275/60-20 or a Nitto Terrain Grappler. 20 inch wheels combined with aggressive tread tires on these trucks look awesome.
<br />
<br /><br />There are actually plenty of options for A/T tires that'll go on 20' rims. I recommend the Michelin LTX M/S in 275/60-20 or a Nitto Terrain Grappler. 20 inch wheels combined with aggressive tread tires on these trucks look awesome.<br /><br /><br /><br />
I just took delivery of my 2007 GMC SLE reg cab short box Z71/Z85 and it came with the 265/70/17 Goodyear Wrangler AT/S with N88 aluminum wheels. Very nice looking really. I bought the 20" Yukon XL polished wheels, same height aspect, same offset with 275/55/20 Bridgestone Alenza Dueler H/L tires. Found a set of those on eBay for $1365 delivered, a matching spare wheel for $50 and two Dueler take-off tires for $235. Sold my wheels and tires for $1000 including the spare. I kept the tire pressure sensors because the buyer didn't need them, and added Gorilla chrome lugs. A much better set-up for not that much money. There are deals out there if you look for them.
zoz
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
