Britney
99silveradoz71
Anyone have any thoughts? I'll start off by saying she's definitely not the young, thin athletic type we saw in Baby One More Time. She definitely has the hips of a mom, has lost the stomach, and her thighs appeared to almost rival mine in size, ha. But hell, she's still Brit.
I have to admit, her new song is catchier than most of her previous stuff. But I'm not too hot on the fact that her AND the Backstreet Boys are coming back.
I thought we were rid of them! :rolleyes:
WELL
I saw the award opener tonight... She looked like a drunk chunky cheerleader. I think the comeback might need a little more work.
My personal opinion is that I hope she invested wisely because she is done.
+1 I saw the highlights of the show. He lip syncing was off, so was the dance choreography(This was a difficult word to spell) was aweful. It looked like she had no enthusiasm. She needs to go back to drinking, being psycho, and neglecting her kids. :rolleyes:
hell, and i thought she looked hotter now then before she went psycho ... i could care less how she sounds .. or how well she pretends to sing on stage .. just nice curves ... (but i have always hated the ones that are real skinny)
She was totally hot back in the 'Baby one more time' days. Not so much anymore. Happens a lot...with a lot of women. I saw a decent amount of people from my class when me and my buddy went to our high school for the football game this past Friday night, and wow. Might be study munchies from college, or they need to start drinking light beer or something.
Britney's stage performances were always bad, but now people see that she put on a lot of mommy weight, and no longer can look at just the appearance, they have to look at the singing, and in her case lip syncing. But IMO I do think she looks better now. I hate overly small females.
Guest chevydeerhunter
She didn't look bad at all. I think she would've been better off just standing there lip syncing instead of trying to dance around looking like a drunken milf.
it was funny to watch them diss her on msnbc. They showed her old performances next to this one and it was a joke. Britney was terrible.
yeah, 2 kids before 25. She got rode hard and put away wet.
Judging by the looks of K-Fed, she just got rode and put away wet.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
    • About 8 months after an alignment job by the dealer I started experiencing a pretty significant clunk in the front end on hard left hand turns usually parking lot speeds almost at lock.  Occasionally get the same on hard rights too.   Discovered that the lower control arm attachment bolts are TTY and only to be used for a single use. And then I found some evidence of a TSB that indicates you can over torque those fasteners to about 130 foot pounds.   Asked a local shop to investigate and they found 3 out of four bolts loose and retorqued.   I've ordered the MOOG    K100421 lower control arm bolt kit that is completely reusable and not TTY.    Is the 80 ft pounds a realistic number?  Anyone have experience with those bolts?
