Sort Of Stumped
dualscoopinchevy
Hey guys,
About 2 months back I ordered and installed an accel super tune ignition kit w/bigger coil for my 98 5.7L GMC. I also did some exhaust work right after that (replaced muffler and intermediate pipe with flowmaster super40 and a upgraded dynomax intermediate- still has O2 sensors). A few days after the new upgrades, and it had been running great, it died on me while going down the road one evening. Me and my dad changed the fuel pump....not the problem. Had it towed to the dealership, they said they needed to change the distributor because the holes were stripped where the rotor and cap needed to mount in. After I got it back, I noticed it was lacking the pep it had prior to the breakdown. I had to take it on a long road trip immediately after. after a few hours of driving, it began to act up horrible, no acceleration, surging, wasnt fun. And I was hours away from home. Well it made it the whole trip, and began to get a little better, and is still better now. But, it is still surging or missing some, not accelerating like it should, and the mileage has dropped. It will not throw a code. At all. I have changed spark plugs again, they looked like they had been burnt almost, but they were only a month old. I had ordered a Wait4me tune the day it broke down originally, and ran it for a couple of weeks recently, it improved the truck a little bit, but it still isnt running near like it should. So i have the stock pcm in there now.
If I take it to the dealer again, will their diagnostic computers be able to tell me whats wrong even if there is no code being thrown?
Do you think the hotter coil is burning stuff up? Ive got accel 8mm wires and ugroove plugs.
Is there some reason the a factory style cap and rotor they put in there with the new distributor cant handle the load that an accel brand rotor could?
Any insight on what a dealer can diagnose would help, or if you have any ideas what my problem might be i'd appreciate it. Thanks yall
Jeremy
Hey guys,
Jeremy
For what its worth, I wonder if your hotter coil and better wires means you should possibly need to open the gap on your plugs. It may be that you need an bigger gap to handle the new goodies. Just an opinion. Also, I think your dealer can get info even if your truck is not throwing a code or at least an SES light. Proof is I took my truck in Sat and today they tell me I need "another" ignition switch. The second one in just over a year. Their code reader pulled it up. I think your factory cap should handle it but maybe you should see if accel offers an alternitive to your truck due to the increase in voltage. Just my .02 worth.
I'd say gap as well....if I remember right, I think the basic 5.7 gap is .035. If the gap is at .035 now, try .040 or .045.
Also make sure your wire separators are in very good condition and the right size. Using the stock separators with aftermarket performance wires will squeeze the thicker diameter to a point that cross fire could happen between wires.
thanks for the replies guys.
the stock gap is actually .060 or .065, i forget, but i increased it just a hair, maybe I should go a full step up.
I've never heard that about the stock wire looms before, I know that I have the new wires shoved in there. I'll check that out.
I'll also go ahead and fork over some money to have them check it out so I dont waste to much time and money searchin blindly I guess.
Anymore ideas would help!
Thanks again
Thanks again
Good Idea to get it scanned. You never know it just might need to be cleared and you are good to go. You stated that your plugs looked burn't already, maybe purchase a fresh set of platnums, (your choice of man.), and set the gap to .65-possibly.70 and see what you get. Maybe like I said since you have all accel ignition you may want to check into a distributor cap. There may be some differences compared to stock, I don't know worth checking in to I guess. Again just my opinion. Hope it helps.
i've thought about putting the stock stuff back on, but i'm not sure if i can put the stock coil back on since I had to cut the bracket to put the bigger one on. im not sure off hand how big of a job it'd be to put on another bracket. anywho....
I took it in this morning to the dealership, apparently they couldnt do much with a computer since it wasnt throwing a code. I figured they'd have a computer that could tell me more than that. But he was able to drive it with the scanner hooked up, and picked up some random misfiring. Primarily #5, also 3, 7, and a little from 1 and 4. But by far more from 5. He said he thought since the ignition was pretty much all new, that it could be the injectors, since they've never been cleaned (it's a 98). So i may try that monday morning. He said if that isnt it, they may check to see if a regulator in the throttle body (tryin to remember what he said) could be the problem if it's not spraying properly.
Should I have the injectors cleaned?
Could any of this be a result from switching to a higher octane gas? My dad ran 87 in it for years, and upon anticipation of a tune from wait4me, I started running 89 then 93. Could this have caused a problem. As of now, I have gone back to 87 until I can get things figured out.
I'm going to take the wires out of the stock looms tom. morning and see if the crossfire idea may be happening (between school and work not a lot of time to do stuff lately)
Thanks for continuing to help guys. If you have any ideas about the new info please let me know!
Jeremy
with changing the fuel pump you may have stirred up some trash which clogged the injectors ...
if it still doesn't feel just right, and is missfiring some .. i would check the dist that they installed to make sure there isn't to much play in the shaft .. and that the rotor fits on snuggly and doesnt jump around.
in california, because of our bad gas, we have a special policy for those injectors, they are coverd for 10 yrs or 200000 miles for free replacement, they clog all the time on those motors, and if it werent for all the aftermarket stuff i would say that that is definetly your problem... If your regulator is leaking then you would have a problem with long cranking to, if you dont have long cranking then i doubt that is a problem... but even tho they cleaned the injectors, they still may not be performing like they should and may need to be replaced...
but now u have more info, if it keeps doing it at least you know that #5 is your biggest problem cylinder, so consetrate on checking that cylinder for ignition problems that you may have caused with the tune....
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
