How Do I Hoop Up 7 Pin Trailer Harness
My 99 Tahoe with the heavy duty towing package just has 4 wires hanging where the 4 pin connector must have been before.
I want to hook up a 7 pin harness and trailer brake controller under the dash.
How difficult is this on this truck?
Any tips would be greatly appreciated!!!
  • 1 month later...
I bought a 4 pin to 7 pin adapter off of Ebay. Don't remember exactly how much, but it wasn't that much.
Anthony
In 99 the Tahoe did not have any kind of plug that was factory wired - the harness that went to the back bumper area had 7 wires for use on travel trailers - the brake and +12V were only wired to the engine compartment, there you had to install a fuse for the 12V in the relay box and run the blue brake wire through the firewall for your controller. The extra 3 wires are for brakes, +12V, and back-up lights. The other 4 are Tail/marker lights, RH turn/brake, LH turn/brake, and GND.
The controller also had to be wired into the proper ckts on the fuse block - you need 12V. Gnd, the blue wire to the brakes, and a signal wire from the brake switch. I think there are spare pins on the fuse/connector block located on the left hand side of the floorboard. I had mine wired directly to the brake switch wire- just to make sure. I mounted my controller on the right side of the steering wheel under the dash - right under the 4WD selector switch.
As for adaptors I have seen 7 pin to 4 pin models - but there is no way to make a 4 pin into a 7 pin.
