Took My Blazer Off Roading For The First Time!
I've always wanted to do some real off roading (since I was 14!). I've done a few off road jaunts, but nothing like this! I took my 1993 S-10 Blazer to Badlands ORV park in Western Indiana the other day. I was there on a weekday by myself, so it was pretty deserted. I didn't venture onto the real tough Jeep trails, but I did climb some hills and ride some trails. I was pretty impressed with what the Blazer would go through and over considering I'm running stock tires (mild A/T 235/75-15s) and running boards! I saw some Jeeps climbing some rocks that at first I didn't realize people drover their Jeeps over them! Pretty crazy, I knew my Blazer wouldn't make it!
I'd load pictures, but I'm feeling lazy. Sorry. If you really want them, let me know and I'll load them...
I'm considering buying new tires for the Blazer as well as new tires for my Suburban. I'm fairly set on 30x9.50-15 BFG ATs for the Suburban, but I'm considering the BFG MTs in either 30x9.50-15 or 31-10.50-15 for the Blazer. Does anyone know if the there would be problems with the 31s for the Blazer (rubbing etc.)?
Thanks!
Looks like a lot of fun....thanks for posting the pictures!
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
