Fog Lights On Nbs
Has anyone done a wireing mod to make the fog lights stay on everytime you start your vehical. I wish you could turn the fog lights on and then they would be on for as long as you want. Its a pain to keep pushing the button on the dash everytie you start up. I like to have mine on all the time, day or night.
You might want to switch fingers if that one hurts. Kidding. Check out the link in my sig if you are interested in fogs that actually produce some light.
Daddy
That's probably one of the last upgrades that I want to do to my truck. One, have the fog lights come on with the low beams and two, get more might from them. I'm probably going to follow daddy's lead and rewire so I can run 9005 HIDs. Still waiting for a way to have them come on with the low. I have a $20. reward for anyone that can make that happen. Anyone want to up that to $40., maybe $60 or more? :lol:
They are fog lights, not daytime driving lights. And pushing that button in to turn them on every time you start the truck, that is truly a major effort. Did it ever occur to you that other drivers may not care for your additional lights being always on? And what may I ask, is the purpose for keeping these on during daylight hours?
For myself, I like the look of the fog lights on with the low beams. I run all of my vehicles like that at night. Pushing the button is a PITA. That's why many other things in life are automatic. Things such as door openers, paper towel dispencers, headlights, wipers ect, ect... So we need the fog lights to come on by themselves too :lol:
Yes, and GM has probably a good fix in the works - a fog sensor! And that is the only way your fog light will come on - ever.
They are not Fog Lights, they don't do an ounce of good in the Fog. They are just really cheap supplimental lights which serve no purpose other then for people to think their trucks look "cool" with them on.
Keep in mind that any additional lights on all the time is not free. Your alternator has to work harder to supply the current to additional lights. Turning off your daytime driving lights and not using fog lights actually saves you a small amount of fuel.
I agree with you there they are not fog lights. True fog lights that serve a purpose to cut through fog are yellow. these are only for looks, especially in the new nbs trucks since the light output sucks. Upgrading them to 9005's is a definite must do. In my 05 Silverado it was easy all you had to do was cut one tab on the bulb. I don't understand why GM changed there bulbs in the nbs. Oh well thanks to guys like Daddy, its an easy fix solution.
With the upgrade, I now have two full sets of headlights on when I drive with my fogs on. I agree, from the factory, they are pretty well useless. With the upgrade, I can actually drive without my lows on and see just fine. Not to mention, it looks freakin' awesome coming down the road with all four lights on when they are all actually bright!!!
Daddy
just a note, not bashing ot anything at all ... some of the best fog lights out there are not even yellow ... it is more in the design of the reflector and the lens and the location it is put on the ride .. and how it is aimed ... then it is in the color of the bulb ...
I found this link when I was looking for info on the add-a-circuit thing. Warning: there is a big ugly picture greeting you when you open the website.
http://mouser.org/projects/tacoma/foglights_mod/
Hum... just read through that quick. I wonder if it will work for us?
I have my Owners manual and checked the diagram for the fuses, our fog lamp fuses are in the underhood fuse block. Not sure if that would make it more difficult or not.
    250.3k
    Ragg-Boy
    Ragg-Boy
  • Who's Online   6 Members, 0 Anonymous, 965 Guests (See full list)
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
