Fender Flares
The NBS 900 series trucks have flared fenders, but the detachable plastic body color flares are gone. Are these even optional on the NBS 07 and later? Personally, I prefer the plastic fender flares on my '06 Z71 because they are replaceable if they get damaged. Replacing a damaged fender/bed side is a lot more expensive and tedious.
No Pete,Nothing available from GM.
I think Bushwacker has some out though.
I've seen only one GMT 900 with fender flares on a Silverado 1500 4x4 crew cab truck my cousin's husband bought new this past spring. I'm still not convinced that it left the factory with 'em on.
Honestly, I thought they looked a bit goofy with the stock wheels and tires. The 800 series trucks however look great with flares, especially painted ones.
I think that the flares were eliminated on the 900 series by flaring out the fenders themselves. Another cost cutting move I suppose. :rolleyes:
I agree that the painted factory fender flares gave the truck a nice custom touch. It somehow looks cheap without them, especially the 4X4 ones.
He might have bought it that way,but it didn't leave the factory with'em on.
The dealer might have added them.
That's what I thought -- he tried to argue that one with me. The flares were regular black unpainted ones on a Silverbirch Metallic with LS trim.
I would like to see pictures of that truck.
Also I have an 2001 Z71, what is the part number for the painted flares for my truck? I'd love to have them on my truck.
Well bushwaker makes them for sure.... Pretty sick too. I wish they would put pictures with regular cabs so i could see what my new truck would look like! BTW this is my first real post. 2007 5.3L 4x4 with Z71 Victory Red - i'll have pics soon.
Anyways here's some of bushwacker's pics.
I saw a Victory Red NBS CC tonight with the flares on it. I think it was jacked-up like photo 2 and 3, but it had the flares from the last / bottom photo (with what looked like rivets). It's not something *I* would probably do, but they looked alright... Definitely a different look.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
