Brake Tsb?
I heard from a friend that there was a TSB out for the brakes on the NNBS silverados and Sierras. It supposedly specifically mentions the squealing brake issue that so many of us have complained about. Is there really one out there and if so, what does it actually say?
Any help would be appreciated. My brakes (specifically the rear drums--passenger especially) squeal every time I apply them. I know they are not bad with only 5000 on them so it just drives me crazy. Also, I work nights, so when I come home in the morning, I'm sure it disturbs my neighbors.
This could be what was being talked about...
Document ID# 1993275
2007 Chevrolet Silverado - 2WD
Subject: Disc Brake Squeak Or Noise On Brake Apply - keywords ABS left pad right rotor #PIT4213A - (06/27/2007)
Models: 2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2005-2007 Chevrolet Silverado Classic with RPO JF3 or JF7
2005-2007 GMC Sierra Classic with RPO JF3 or JF7
2007 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
This PI was superseded to update Recommendation/Instructions. Please discard PIT4213.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some owners may comment of a front brake squeal noise during brake apply after a cold soak. Some brake noise may be normal and for more information please review bulletin 00-05-22-002I.
Recommendation/Instructions:
If the front brake squeal is found to be abnormal, updated pads with a new chamfer and re-designed insulator have been released to correct this concern. Replace the front brake pads with part number 25852957.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
and this one:
Document ID# 1972099
Subject: Disc Brake Warranty Service and Procedures #00-05-22-002J - (05/15/2007)
Models: 1999-2008 GM Passenger Cars and Light Duty Trucks
2003-2008 HUMMER H2
2006-2008 HUMMER H3
1999-2004 Isuzu Light Duty Trucks (Canada Only)
2005-2008 Saab 9-7X (Canada Only)
1999-2008 Saturn Vehicles (Canada Only)
This bulletin is being revised to include the 2008 model year and revise the requirements for submitting claims using H9709 - Brake Burnish. Please discard Corporate Bulletin Number 00-05-22-002I (Section 05 -- Brakes).
For your convenience, this bulletin updates and centralizes all GM's Standard Brake Service Procedures and Policy Guidelines for brake rotor and brake pad service and wear. For additional information, the Service Technical College lists a complete index of available Brake courses. This information can be accessed at www.gmtraining.com > resources > training materials > brakes courseware index. In Canada, refer to Service Know How course 55040.00 and Hydraulic Brake Certification program 15003.16.
Important: PLEASE FAMILIARIZE YOURSELF WITH THESE UPDATES BEFORE PERFORMING YOUR NEXT GM BRAKE SERVICE.
There are five (5) key steps that must be performed to complete a successful brake service:
Measure and Document Rotor Thickness* - determine rotor refinish/replace
Clean Mating Surfaces - hub, rotor and wheel
Proper Rotor Refinish and Documentation
Measure, Document and Correct Lateral Run Out (LRO)** - Maximum 0.050 mm (0.002 in)
Reassemble with Proper Torque and sequence -- wheel lug nuts
* The bulletin refers to Minimum Thickness specification as the minimum allowable thickness after refinish. Always refer to SI to verify the spec stamped on the rotor is the minimum thickness spec after refinish and not the discard spec.
**The bulletin will refer to LRO maximum specification as 0.050 mm (0.002 in). However, some trucks may slightly differ. Refer to SI to verify specifications.
Bulletin Format / Key Page Number
Reference:
Bulletin Topic
Page #
Repair Order and Warranty Information Network System (WINS) Required Documentation
2
New GM Brake Service Procedure (Hubless and Hubbed / Trapped / Captured Rotors)
2
Brake Lathe Calibration Procedure (Bench / On-Car Lathe)
5
Brake Pulsation (Rotor Thickness Variation -- Lateral Run Out [LRO] / Corrosion)
6
Brake Rotor Clean-up Procedure
7
Brake Noise
8
Frequently Asked Questions
8
Brake Warranty (Rotor / Pad)
8
Tools and Parts Information
9
Labor Operation and Labor Time Information
9
Worksheet -- Brake Lathe Calibration
10
Attachment Form -- GM Brake Service Repair Order Documentation for Required Measurements
11
***REPAIR ORDER / WARRANTY CLAIM REQUIRED DOCUMENTATION
Important: When using any one of the brake labor operations listed in this bulletin (except for H9709 -- Brake Burnish) , the following three rotor measurements (1. Original Rotor Thickness, 2. Refinished Rotor Thickness and 3. Lateral Run Out) are required and MUST be written/documented on the repair order, or for your convenience, complete the form (GM Brake Service Repair Order Documentation for Required Measurements) found on the last page of this bulletin and attach it to the repair order. If the Warranty Parts Center generates a request, this Documentation/Form must be attached to the repair order that is sent back.
Important: Documentation of brake lathe maintenance and calibration as recommended by the lathe manufacturer must be available for review upon request.
Repair Order Documentation -- Rotor Original And Refinished Thickness -- REQUIRED
When resurfacing a brake rotor or drum, the ORIGINAL thickness (measured thickness before refinish) and REFINISHED thickness (measured thickness after refinish) MUST be written/documented on the repair order hard copy for each rotor serviced. If a rotor replacement is necessary, only the Original thickness measurement needs to be recorded.
Repair Order Documentation -- Lateral Run Out (LRO) and Correctional Plate Part Number -- REQUIRED
When using any one of the brake labor operations listed in this bulletin (except for H9709 -- Brake Burnish) , the rotor assembly MUST be measured for Lateral Run Out (LRO) (follow brake procedure steps 9-11). If the LRO measurement is greater than 0.050 mm (0.002 in), correct it by using the proper Brake Align® Correctional Plate (DO NOT refinish new rotors or newly refinished rotors to correct LRO). This LRO measurement, and the Correctional Plate part number used to correct the LRO, MUST be written/documented on the repair order hard copy. If no correction is necessary, only the LRO measurement for each rotor serviced needs to be recorded.
Important: Correction plates can only be used on Hubless rotor design. A correction plate part number can not be used with Hubbed, Trapped or Captured type designed rotors.
Warranty System Documentation -- Lateral Run Out (LRO) -- REQUIRED
When using any one of the brake labor operations listed in this bulletin (except for H9709 -- Brake Burnish) , the Lateral Run Out (LRO) measurement (as measured in the "Repair Order Documentation -- Lateral Run Out" section above) MUST be documented in the Warranty System (WINS) in the Failure Code/DTC field of the claim submission (refer to the Claims Processing Manual, Section IV, Warranty Claim Data, page 6, Item G) and correspond to the Labor Operation used.
Important: Because the Warranty System Failure Code/DTC field can only accept five characters/numerics, the first 0 is dropped from each LRO measurement, the left side (drivers side) is recorded first, then an R for right side (passenger side), then record the right side measurement. LRO should be recorded in Warranty System Failure Code/DTC field in inches only (not mm).
Example: If a Labor Operation for both fronts is used and the left front rotor LRO measurement is (0.002 in) and the right front rotor measurement is (0.0035 in), it should be recorded as 02R03. If a Labor Operation for both rears is used and the left rear rotor LRO measurement is (0.002 in) and the right rear rotor measurement is (0.0035 in), it should be recorded as 02R03. If a single side labor operation for the front or rear left side is used and the left side is (0.002 in), then record as 02RNA. If only the right side is used and the right side is (0.002 in), then record as NAR02 (NA = Not Applicable).
Repair Order Documentation -- Explanation of Part Replacement -- REQUIRED
If replacement of a brake component is necessary, proper documentation on the repair order is required. See the following examples:
• Brake rotor replacement -- Customer comment was brake pulsation. Rotor was refinished on a prior brake service. After rotor measurement, it was determined that refinishing the rotor again would take it under the Minimum Thickness specification.
• Brake pad replacement -- Customer comment was brake squeak noise. On inspection, found pads contaminated by fluid leak at caliper.
NEW GM BRAKE SERVICE PROCEDURE
Remove the wheel and caliper.
Measure rotor thickness. In order to determine if the rotor can be refinished, do the following steps:
Important: If performing routine Brake Service for worn pads only, and the rotors are not damaged and measure within specification - DO NOT REFINISH ROTORS.
2.1. Remove the rotor(s).
2.2. Measure the rotor for original thickness using a brake micrometer. Multiple measure points should be taken and the lowest measurement should be recorded.
2.3. Reference the Minimum Thickness specification stamped on the backside of the rotor or SI for Minimum Thickness specification/other. In most cases, the rotor should be refinished unless the measurement taken makes it obvious that refinishing the rotor would take the measurement under the Minimum Thickness specification (then replacement is necessary). DO NOT use any other manufacturers rotor specifications.
***Record the lowest ORIGINAL rotor thickness measurement on the repair order hard copy as noted in the "Repair Order Documentation -- Rotor Refinish" section of this bulletin.
Clean all of the mating surfaces between the hub, the rotor and the wheel using the J 42450A -- Wheel Hub Cleaning Kit and J 41013 -- Whiz Wheel®.
If rotors are not to be refinished - Go To Step 8.
Important: Cleaning all mating surfaces and making them free of corrosion, burrs and other debris (which includes removal of Hubless rotors) is critical and MUST be performed whether using an On-Car or Bench Lathe Refinish Procedure.
Be sure to follow the appropriate refinishing procedure listed below for the type of lathe you are using.
Important: Only replace the rotors if they do not meet the Minimum Thickness specification.
Important: DO NOT REFINISH NEW ROTORS.
Important: Only remove the necessary amount of material from each side of the rotor and note that equal amounts of material do not have to be removed from both sides on any brake system using a floating caliper.
Important: Prior to making the cut, install the recommended clip-on style disc silencer supplied with the lathe. Use of this silencer is critical to prevent chatter from occurring during the cut.
Bench Type Lathe
5.1. Refinish the existing rotor on an approved, well-maintained lathe to guarantee smooth, flat and parallel surfaces.
5.2. Check for clean and true lathe adapters and make sure the arbor shoulder is clean and free of debris or burrs. For more information, see the "Brake Lathe Calibration Procedure (Bench-Type)" section in this bulletin.
5.3. On the outboard area of the rotor, position the cutting tools one eighth of an inch into the brake pad area of the rotor. Feed the cutting tools into the rotor until they cut the rotor to new metal, a full 360 degrees. Zero each dial and back off a full turn.
5.4. Move the cutting bits to the middle of the rotor and do the same procedure. If zero is passed during the process, reset zero. Back off a full turn.
5.5. Position the cutting bits one eighth of an inch inside the inboard (closest to the hub) edge of the brake pad contact area. Do the same procedure. If zero is passed during the process, reset zero.
5.6. Back off a full turn and position the cutting bits all the way inboard in preparation to refinish the full rotor surface. Advance both tool cutters to the zero setting plus just enough to clean up the entire rotor surface.
5.7. After completing the refinish, sand both sides of the rotor for approximately one minute per side using a sanding block and 130-150 grit sandpaper to obtain a non-directional finish.
On-Car Type Lathe
5.1. Reinstall the rotor(s).
Important: When using the On-Car lathe on vehicles equipped with limited slip (or posi-trac) rear system, it is critical that the rear drive shaft is disconnected/disengaged prior to operation of the On-Car lathe. Remember to mark and re-index the drive shaft correctly on re-assembly to prevent creating driveline vibration. Whenever the lathe drive motor is being switched on, the operator MUST keep their body out of the wheel well area until the machine has reached its normal operating RPM.
5.2. Refinish the existing rotor on an approved, well-maintained lathe to guarantee smooth, flat and parallel surfaces.
Important: When raising the vehicle on the lift, be sure to have it at a good working height (waist high is average) to accommodate mounting the On-Car lathe. Optimally, the center piston on the lathe trolley will be mid-travel. If the lathe trolley center piston is completely compressed (bottoming out) or inversely fully extended and hanging off the vehicle hub, this could affect the calibration time of the lathe.
5.3. Select the correct adapter for the vehicle you're working on and mount it to the hub with the vehicle lug nuts. Hand tighten 34-41 N·m (25-30 lb ft) the nuts using equal torque. DO NOT use impact wrenches, excessive torque will damage the adapter.
Important: Ensure the adapter sits flush on the rotor hat surface. Be sure to remove any rust, rotor retaining clips, etc. that may preclude the adapter from sitting flat on the mounting surface.
5.4. Connect the lathe to the adapter, turn on the lathe and activate the computer to compensate for run-out in the hub.
5.5. Once the computer indicates the compensation process was successful, on the outboard area of the rotor, position the cutting tools one eighth of an inch into the brake pad area of the rotor. Feed the cutting tools into the rotor until they cut the rotor to new metal, a full 360 degrees. Zero each dial and back off a full turn.
5.6. Move the cutting bits to the middle of the rotor and do the same procedure. If zero is passed during the process, reset zero. Back off a full turn.
5.7. Position the cutting bits one eighth of an inch inside the inboard (closest to the hub) edge of the brake pad contact area. Do the same procedure. If zero is passed during the process, reset zero.
5.8. Back off a full turn and position the cutting bits all the way inboard in preparation to refinish the full rotor surface. Advance both tool cutters to the zero setting plus just enough to clean up the entire rotor surface.
5.9. After completing the refinish, sand both sides of the rotor for approximately one minute per side using a sanding block and 130-150 grit sandpaper to obtain a non-directional finish.
5.10. Dismount the lathe, but leave the lathe adapter attached to the vehicle.
Once the rotor has been properly machined, wash the rotor with soap and water (use a mild dish washing soap) or wipe it clean with GM approved brake cleaner, P/N 12378392 (Canadian P/N 88901247).
Important: Thoroughly cleaning the rotor will prevent the possible transfer of finite metal dust left as a by-product of machining to the pad material during the seating process, thus reducing the opportunity for squeaks or other noises to occur.
***Record the REFINISHED rotor thickness measurement on the repair order hard copy. Refer to the "Repair Order Documentation -- Rotor Refinish" section of this bulletin.
Setting up to measure for Lateral Run Out (LRO):
Bench-Type Lathe
8.1. Ensure that the mating surfaces of the rotor hat section and the hub mating surface are clean and free of debris.
8.2. Mount the new, original or refinished rotor onto the vehicle hub.
Important: Always hold the rotor on the bottom half so any debris that may be dislodged from the vents will fall out instead of falling into the mounting area. Any movement or jarring from the rotor falling over on the studs can release rust from the vents on the rotor.
8.3. Tilt the top of the rotor in towards the vehicle so you can see the studs and ease the rotor onto the studs.
8.4. Slide the rotor all the way to the hub and hold it in place until you have placed one of the conical washers (with the tapered hole side facing out) and run the first lug nut up tight by hand so the rotor doesn't move when you release it.
8.5. Place the conical washers on the rest of the studs (with the tapered hole side facing out), start and snug the lug nuts by hand.
8.6. Using the one half inch drive impact wrench and a torque stick (J 39544) or equivalent, start with the lug nut opposite of the one you first tightened by hand and tighten the lug nuts using a star pattern until they touch the hub but do not completely torque. Then again, starting with the first lug nut you tightened by hand, tighten all the lug nuts in a star pattern to the specific vehicle torque specification.
8.7. DO NOT reinstall the caliper or the wheel at this time.
On-Car Type Lathe
8.1. Leave the On-Car adapter on the wheel.
8.2. Proceed to Step 9.
Fasten the dial indicator to the steering knuckle so that the indicator needle contacts the rotor outboard friction surface approximately 6.35 mm (0.25 in) from the rotor's outer edge. The stylus should be perpendicular to the friction surface of the rotor.
Important: Make sure the dial indicator needle tip is screwed tight, a loose tip could cause false readings.
Measure for LRO. Follow the procedure below to determine if the LRO is within specification (0.050 mm (0.002 in) or LESS).
10.1. Rotate the rotor and locate the point on the rotor where the lowest dial indicator reading is indicated and set the dial indicator to zero.
10.2. Rotate the rotor from the low point and locate the point with the highest dial indicator reading (rotor "high spot"). Note the amount and mark the location of the "high spot" on the rotor and mark the closest wheel stud relative to this location. If the high point falls between two studs, mark both studs. In instances where the vehicle has "capped lug nuts" you should mark the hub.
***Record the rotor Lateral Run Out measurement on the repair order hard copy. Refer to the "Repair Order Documentation -- Lateral Run Out" section of this bulletin. Measuring for LRO is critical and MUST be performed whether using an On-Car or Bench Lathe Refinish Procedure.
Important: ***This measurement must also be documented in the Warranty System (WINS) in the Failure Code field of the claim submission. Refer to the "Warranty System Documentation -- Lateral Run Out" section of this bulletin.
If the Lateral Run Out (LRO) measurement is 0.050 mm (0.002 in) or LESS, no correction is necessary. Go to Step 16 if this is the first rotor completed. Go to Step 17 if this is the second rotor completed. If the LRO is GREATER than 0.050 mm (0.002 in), go to Step 13.
If the LRO measurement is greater than 0.050 mm (0.002 in), use the following procedure to correct for LRO:
Important: If the LRO measurement is over 0.279 mm (0.011 in), determine the source or cause of the LRO and correct it (i.e. verify drive axle nut torque specification, refinished rotor is source of LRO due to a lathe qualification issue - see "Brake Lathe Calibration Procedure").
Hubless Rotor
13.1. Remove the rotor and using the Brake Align® application chart, choose the correct plate to bring the rotor LRO to 0.050 mm (0.002 in) or less. The plates come in 0.0762 mm (0.003 in), 0.1524 mm (0.006 in) and 0.2286 (0.009 in) compensation. For more information on proper plate selection, see the instruction video/DVD included in the "Brake Align®" kit.
13.2. Align the V-notch of the selected Brake Align® correction plate to the marked wheel stud ("high spot") or between the two points marked (if the "high spot" is between two wheel studs).
Important: IF Brake Align® Correction Plates are not available for the vehicle being serviced, refer to SI Document ID# 836495 for correcting LRO.
Important: Per Brake Align® manufacturer, NEVER attempt to stack two or more Correction Plates together on one hub. NEVER attempt to reuse a previously installed Correction Plate.
13.3. Reinstall the rotor using the same method and precautions as the first time - found in Step 8. Make sure to index the rotor correctly to the marks made in step 10, otherwise LRO will be comprised.
Hubbed / Captured / Trapped Rotor
13.1. Measure the rotor thickness.
13.2. Refinish or replace the rotor (see Service Information for further details).
Use a Dial Indicator to measure the rotor to verify the LRO is within specification.
If using,
BENCH LATHE -- DO NOT remove conical washers and lug nuts at this time.
ON--CAR LATHE -- You must remove adapter and install conical washers and lug nuts to retain rotor position.
Important: For Hubless rotor design, while removing the adapter, you must hold the rotor tight to the hub and install the top conical washer and lug nut first to ensure no debris falls between the surface while removing the adapter. Then, install the remaining conical washers and lug nuts. Otherwise, LRO will be comprised.
Perform Steps 1 - 12 on the opposite side of the vehicle.
After both sides of the vehicle have LRO measurements within specification, perform the following steps:
17.1. Reinstall the calipers and pads.
17.2. Pump the brakes to pressurize the calipers.
17.3. Remove the lug nuts/conical washers.
17.4. Install and properly torque the wheels.
Important: It is critical to follow the star pattern wheel torque procedure and use the proper tools (torque stick or torque wrench) as referenced in SI.
Road test the vehicle to verify the repairs.
***Indicates measurements must be written/documented on the repair order and/or in the warranty system.
BRAKE LATHE CALIBRATION PROCEDURE
BENCH-TYPE LATHE
Calibration of the brake lathe should be performed and recorded monthly. Use the following procedure to calibrate a Bench-type brake lathe:
After refinishing a rotor, loosen the arbor nut and while holding the inside bell clamp to keep it from rotating, rotate the rotor 180 degrees.
Retighten the arbor nut and set the dial indicator on the rotor using the same instructions as checking the run out on the vehicle.
Rotate the arbor and read the runout.
Divide the reading by two and this will give you the amount of runout the lathe is cutting into the rotor.
Important: If there is any runout, you will need to machine the inside bell clamp in place on the lathe (this procedure is for a Bench type lathe ONLY, DO NOT machine inside the bell clamp on an On-Car type lathe).
Machining the Inside Bell Clamp (Bench Type Lathe Only)
Any nicks or burrs on the shoulder of the arbor must be removed. An 80-grit stone can be used to accomplish this. Spray WD-40® on the shoulder and with the lathe running, hold the stone flat against the shoulder surface using slight pressure. When the burrs are gone, clean the surface. Burrs must also be removed from the hub of the inside bell clamp. This can be accomplished with the stone and WD-40®. Keep the stone flat on the hub while removing the burrs. After removing the burrs, clean the hub.
Place the bell clamp on the arbor of the lathe and use the small radius adapters first and then spacers to allow you to tighten the arbor nut to secure the bell clamp to the lathe. Position the tool bit in the left hand of the rotor truer so you can machine the face of the bell clamp. Machine the face of the bell clamp taking just enough off of it to cut the full face of the clamp the full 360 degrees. Before you loosen the arbor nut, match mark the hub of the bell clamp to the arbor and line up these marks before machining a rotor. A magic marker can be used to make the match marks. Machine a rotor and recheck the calibration. Repeat this procedure on all Inside Bell Clamps used.
Important: If runout is still present, contact the brake lathe supplier.
ON-CAR TYPE LATHE
Use the following procedure to calibrate an On-Car brake lathe:
Connect the lathe to a vehicle using the appropriate adapter.
Attach a vise-grip dial indicator to a fixed point in the wheel well and bring the dial indicator to a flat surface on the cutting head.
Turn on the lathe and press the "start" button so the lathe begins to compensate.
Once compensation is complete, note the runout as measured by the dial indicator. Measured runout at this point is overstated given that it is outside the rotor diameter.
If runout is in excess of 0.1016 mm (0.004 in) (0.050 mm (0.002 in) as measured within the rotor diameter), calibration must be tightened. Follow manufacturer's instructions for tightening the calibration of the lathe. This information is found in the manual supplied with the lathe.
Important: If the machine is taking a long time to compensate during normal use, prior to checking the lathe calibration, it is recommended that the machine be disconnected from the adapter and the adapter (still connected to the vehicle) is rotated 180 degrees and the machine reattached. This will accomplish two things:
- It will re-verify the machine is properly attached to the adapter.
- It will change the location of the runout (phase) relative to the machine and thus possibly allow for quick compensation as a result of the position change.
The following information has been added as a reference to ensure your Pro--Cut PFM lathe provides a consistent smooth surface finish over long term usage.
Cutting Tips / Depth of Cut / Tip Life
The cutting tips must be right side up. Reference marks always face up. The cutting tips may not have chips or dings in the surface of the points. Cuts of 0.1016 - 0.381 mm (0.004 - 0.015 in) will provide the best surface finish and the optimal tip life. When cleaning or rotating the cutting bits, make sure that the seat area for the tip on the tool is free and clear of debris.
Cutting Head
On each brake job, the technician must center the cutting head for that particular vehicle using one of the mounting bolt holes on the slide plate. Once the head is centered, it is vital that the technician use one hand to push the head firmly and squarely back into the dovetail on the slide plate while using the other hand to tighten the Allen-Hex bolt that secures the head. Failure to do this could result in chatter occurring during the cut.
Tool Holder Plate (Cutting Head)
The tool holder plate is the plate that the cutting arms are attached to. It can bend or break if a technician accidently runs the cutting arms into the hub of the rotor while the rotor is turning. (Cuts of more than 0.508 mm (0.020 in) can also bend this plate). Once bent, the lathe will most likely not cut properly until the tool holder plate is replaced. In order to verify the condition of the tool holder plate on a machine that will not cut right, remove the mounting bolt and remove the cutting head from the slide plate. With the cutting head titled at an angle, lay the long edge of the tool holder plate down on the flat part of the slide plate. If any gap can be seen between the edge and the slide plate, the tool holder plate is bent and the source of vibration. Also check to ensure that the cutting arms are lying flat on the upper side of the tool holder plate. If the mounting arm post is bent, it will show itself by having the back of the cutting arm lifting off the surface of the tool holder.
Gib Adjustment / Loose Gib
As wear occurs between the slide plate and the box it rides on, you must take up the slack. You do this by way of a moveable wedge, which we call the gib. Your lathe manual details adjustment process, which you should perform when required after monthly checks or whenever surface finish is inconsistent.
BRAKE PULSATION
Brake pulsation is caused by brake rotor thickness variation. Brake rotor thickness variation causes the piston in the brake caliper, when applied, to "pump" in and out of the caliper housing. The "pumping" effect is transmitted hydraulically to the brake pedal. Brake pulsation concerns may result from two basic conditions:
Thickness Variation Caused by Lateral Run Out (LRO). -- LRO on a brake corner assembly is virtually undetectable unless measured. If the brake corner is assembled with excessive LRO (greater than 0.050 mm (0.002 in), thickness variation will develop over time and miles. Excessive LRO will cause the brake pads to wear the brake rotors unevenly, which causes rotor thickness variation. Pulsation that is the result of excessive Lateral Run Out usually develops in 4,800 - 16,000 km (3,000 - 10,000 mi). LRO can be induced when uneven torque is applied to wheel nuts (lug nuts). Improper wheel tightening after tire rotation, spare tire usage, brake inspection, etc. can be the cause of pulsation. Again, it usually takes 4,800 - 16,000 km (3,000 - 10,000 mi) AFTER an event for the condition to surface. The owner or driver does not usually make the connection between the service event and the awareness of the pulsation. The proper usage of torque wrenches and/or torque sticks (torque limiting sockets) will greatly reduce or eliminate the pulsation conditions after wheel service events. The improper use of impact wrenches on wheel nuts greatly increases the likelihood of pulsation after wheel service.
The following are examples of pulsation conditions and reimbursement recommendations:
• If the customer noticed the condition between 4,800 - 16,000 km (3,000 - 10,000 mi) and it gradually got worse, normally the repair would be covered. The customer may tolerate the condition until it becomes very apparent.
• If a customer indicated they had wheel service, ask who performed the service. Then;
- If a GM dealer performed the service, consider paying for the repair and then strongly reinforce the use of torque sticks at the dealer. Two common size torque sticks cover 90% of all GM products. Each technician needs to use torque sticks properly every time the wheel nuts are tightened.
- If the customer had the wheel service done outside of a GM dealership, normally GM would not offer any assistance.
Thickness Variation Caused by Brake Rotor Corrosion -- Rotor corrosion is another form of thickness variation, which can cause a pulsation concern and can be addressed as follows:
• Cosmetic Corrosion:
• In most instances rotor corrosion is cosmetic and refinishing the rotor is unnecessary.
• Corrosion -- Pulsation Caused by Thickness Variation (Lot Rot / Low Miles -- 0-321 km (0-200 mi):
• At times more extensive corrosion can cause pulsation due to thickness variation. This usually happens when the vehicle is parked for long periods of time in humid type conditions and the braking surface area under the pads corrodes at a different rate compared to the rest of the braking surface area. Cleaning up of braking surfaces (burnishing) can be accomplished by 10 - 15 moderate stops from 56- 64 km/h (35 - 40 mph) with cooling time between stops. If multiple moderate braking stops do not correct this condition, follow the "Brake Rotor Clean-Up Procedure" below.
• Corrosion -- Pulsation Caused by Thickness Variation (without rotor flaking / higher mileage -- 3,200-8,000 km (2,000-5,000 mi):
• In some cases, more extensive corrosion that is not cleaned up by the brake pad over time and miles can cause the same type of pulsation complaint due to thickness variation. In these cases, the rotor surface is usually darker instead of shiny and a brake pad foot print can be seen against the darker surface. This darker surface is usually due to build-up, on the rotor material surface, caused by a combination of corrosion, pad material and heat. To correct this condition, follow the "Brake Rotor Clean-up Procedure" below.
• Corrosion -- Pulsation Caused by Thickness Variation (with rotor flaking / higher mileage -- 8,000 + km (5,000 + miles) :
• At times, more extensive corrosion over time and miles can cause pulsation due to thickness variation (flaking). This flaking is usually a build up, mostly on the rotor material surface, caused by a combination of corrosion, pad material and heat. When rotor measurements are taken, the low areas are usually close to the original rotor thickness (new rotor) measurement and the high areas usually measure more than the original rotor thickness (new rotor) measurement (depending on mileage and normal wear). To correct this condition, follow the "Brake Rotor Clean-up Procedure" described below.
Important: In some flaking instances, cleaning-up this type of corrosion may require more rotor material to be removed then desired. Customer consideration should be taken in these situations and handled on a case by case basis, depending on the amount/percentage of rotor life remaining and the vehicle's warranty time and miles.
BRAKE ROTOR CLEAN-UP PROCEDURE
Clean-up the rotors on an approved, well-maintained brake lathe to guarantee smooth, flat and parallel surfaces. Check for clean and true lathe adapters and make sure the arbor shoulder is clean and free of debris or burrs. For more information see the "Brake Lathe Calibration Procedure" section in this bulletin.
Important: In many of these instances, such a minimal amount of material is removed from the rotor that customer satisfaction is not a concern for future brake services. This procedure is intended to "Clean-up" the rotor surface and should be conveyed to the customer as such - not as "cut", "refinish" or "machine", which tends to be terms understood as a substantial reduction of rotor material/life. If the brake lathe equipment being used is not capable of removing minor amounts of material while holding tolerances, further lathe maintenance, repair, updates or equipment replacement may be necessary.
BRAKE NOISE
Some brake noise is normal and differences in loading, type of driving, or driving style can make a difference in brake wear on the same make and model. Depending on weather conditions, driving patterns and the local environment, brake noise may become more or less apparent. Verify all metal-to-metal contact areas between pads, pad guides, caliper and knuckles are clean and lubricated with a thin layer of high temperature silicone grease. Brake noise is caused by a "slip-stick" vibration of brake components. While intermittent brake noise may be normal, performing 3 - 4 aggressive stops may temporarily reduce or eliminate most brake squeal. If the noise persists, a brake dampening compound may be applied to the back of each pad. This allows parts to slide freely and not vibrate when moving relative to each other. Use Silicone Brake Lubricant, ACDelco P/N 88862182 (Canadian P/N 88862496) or equivalent.
The following noises are characteristics of all braking systems and are unavoidable. They may not indicate improper operation of the brake system.
Squeak / Squeal Noise:
• Occurs with front semi-metallic brake pads at medium speeds when light to medium pressure is applied to the brake pedal.
• Occasionally a noise may occur on rear brakes during the first few stops or with cold brakes and/or high humidity.
Grinding Noise:
• Common to rear brakes and some front disc brakes during initial stops after the vehicle has been parked overnight.
• Caused by corrosion on the metal surfaces during vehicle non-use. Usually disappears after a few stops.
Groan Noise:
A groan type noise may be heard when stopping quickly or moving forward slowly from a complete stop. This is normal. On vehicles equipped with ABS, a groan or moan type noise during hard braking applications or loose gravel, wet or icy road conditions is a normal function of the ABS activation.
KEY POINTS -- FREQUENTLY ASKED QUESTIONS
• Q: How do on-car lathes react to Axle Float? Does the play affect the machining of the rotor, either surface finish or LRO?
A: Because the Pro-Cut on-car lathe adjusts in a live mode while spinning the hub/rotor, the dynamics of a floating axle are effectively eliminated. Once the lathe is compensated, there is no difference in the cutting/surface finish and LRO are just the same as with a non-floating axle.
• Q: Which lathe is essential for performing brake work, the bench or on-car?
A: Dealers must have a well maintained bench lathe and well maintained on-car lathe. These lathes need to be calibrated on a monthly basis. BOTH lathes are essential to providing quality brake service.
• Q: Why is it necessary to use a dial indicator to check runout?
A: Both the bench lathe and the on-car lathe will yield EXCELLENT results, but NO LATHE guarantees that the "installed rotor" will meet GM's lateral runout specification. This is why GM insists on the dial indicating of all rotors.
• Q: When should the measurement be taken using a dial indicator?
A: ALL rotors are to be dial indicated after resurfacing and mounting on the vehicle hub, regardless of whether the technician uses the bench lathe or the on-car lathe.
• Q: What is the expected tip life for an on-car lathe?
A: The geometry and composition of the Pro-Cut tips are designed for "single pass" cutting. When using the Pro-Cut the cutting depth should be set to take all material needed to get below rust grooves, eliminate all run-out and resurface the entire disc in a single pass. Cuts of 0.1016 - 0.381 mm (0.004 - 0.015 in) will provide the best surface finish and the optimal tip life. No "skim cut" or "finish cut" is needed. Failure to follow this procedure will shorten tip life. The Pro-cut tips will last between 7-12 cuts per corner. With three usable corners, a pair of tips is good for at least 21 cuts.
• Q: Why does GM recommend the use of single pass (referred to as "positive rake") bench and on-car brake lathes?
A: GM Service and GM Brake Engineering have performed competitive evaluations on a significant number of bench and on-car brake lathes. These tests measured critical performance characteristics such as flatness, surface finish and the ability of the lathe to repeat accuracy over many uses. In each test, single pass lathe designs out performed the competitors. Single pass brake lathes are more productive requiring less time to perform the same procedure.
• Q: Is it okay to leave the caliper/pads installed while cutting rotors using an on-car lathe?
A: On-car lathes should never be used with the pads and calipers installed on the vehicle. The debris from cutting the rotors can contaminate the brake pads/calipers which can lead to other brake concerns and comebacks.
• Q: What is the best way to correct for excessive lateral runout on vehicles with hubless rotors?
A: Regardless of the type of lathe used to resurface hubless rotors, on-car or bench lathe, the preferred method to correct for excessive lateral runout is the Brake Align Runout Correction Plate System. This warranty policy for correction of lateral runout applies to ALL model vehicle, therefore it is essential to inventory a FULL assortment of Brake Align Correction Plates, and a full assortment of sizes, (.003", .006", and .009").
• Q: Is it necessary to measure for LRO on new rotors from GMSPO?
A: All new GM rotors must also be dial indicated after installation. New rotors are NEVER to be resurfaced on any type of lathe.
• Q: What labor operation can be used to claim the time for measuring and/or correcting for LRO?
A: Applicable labor operations include the time for performing a final LRO measurement in the base time allowance. Refer to the "Warranty Information" section of this bulletin in instances where additional time for correcting LRO to meet specification is necessary.
• Q : What information needs to be documented on the Repair Order?
A: Any claim that is submitted using the labor operations in this bulletin, must have the Original Rotor Thickness, Refinish Rotor Thickness and LRO documented on the repair order. For more information, refer to the "Repair Order / Warranty Claim Required Documentation" section of this bulletin.
All Warranty Repair Orders paid by GM, are subject to review for compliance, documentation of lateral runout measurements and the use of Brake Align Plates and may be debited where the repair does not comply with this procedure.
BRAKE WARRANTY
Brake Rotors:
• Brake rotor warranty is covered under the terms of the New Vehicle Bumper-to-Bumper warranty. Reference the vehicle's warranty guide for verification.
• Rotors should not be refinished or replaced during normal/routine pad replacement.
• Rotors should not be refinished or replaced and is ineffective in correcting brake squeal type noises and/or premature lining wear out.
• Rotors should not be refinished or replaced for cosmetic corrosion. Clean up of braking surfaces can be accomplished by 10-15 moderate stops from 56-64 km/h (35-40 mph) with cooling time between stops.
• Rotors should not be refinished or replaced for rotor discoloration/hard spots.
• Rotors should be refinished NOT replaced for Customer Pulsation concerns. This condition is a result of rotor thickness variation, usually caused by LRO (wear induced over time and miles) or corrosion (Lot Rot).
• When rotor refinishing, only remove the necessary amount of material from each side of the rotor and note that equal amounts of material do not have to be removed from both sides on any brake system using a floating caliper.
• Rotors should be refinished for severe scoring -- depth in excess of 1.5 mm (0.060 in).
Important: If the scoring depth is more than 1.5 mm (0.060 in) after the rotor is refinished, it should be replaced.
• It is not necessary to replace rotors in pairs. Rotors may be replaced individually. However, caution should be exercised, as a variance in surface finish may cause a brake pull condition.
• New rotors should not be refinished before installation. Original equipment rotor surfaces are ground to ensure smooth finish and parallelism between mounting and friction surfaces. If a new rotor has more than 0.050 mm (0.002 in) Lateral Run Out (LRO) when properly mounted on the hub, correct it using one of the following methods:
1. For hubless rotor designs, use the correction plate procedure found in the "GM Brake Service Procedure for Hubless Rotors" outlined in this bulletin.
2. For hubbed/trapped/captured rotor designs, refinish the rotor using an On-Car lathe and the procedure outlined in this bulletin.
• Never reuse rotors that measure under the Minimum Thickness specification. In this instance, the rotor should be replaced.
Important: If the Minimum Thickness specification is not visible on the rotor, reference Service Information (SI) for the specific vehicle application. DO NOT use any other manufacturers rotor specifications.
Brake Pads:
• Consideration should be given for covering brake pads up to 39,000 km (24,000 mi) (excluding owner abuse, excessive trailering, or the situations that would not be considered normal use).
• Installation of new rotors does not require pad replacement. Do not replace pads unless their condition requires it - excessively worn, damage or contaminated.
Brake Wear:
Several factors impact brake lining wear and should be taken into account when reviewing related issues:
- heavy loads / high temperatures / towing / mountainous driving / city driving / aggressive driving / driver braking characteristics (left foot or two feet)
The following are conditions that may extend brake lining wear:
- light loads / highway driving / conservative driving / level terrain
TOOL INFORMATION
Tool Description
Tool Number
Brake Rotor Micrometer -- English
J 45021
Brake Rotor Micrometer -- Metric
J 44279
J 42450A
Whiz Wheel®
J 41013
Torque Stick
J 39544 Kit
Dial Indicator Kit (.001 Increments)
J 45101
Conical Washers
J 45101-100
CORRECTION PLATE PART INFORMATION
Correction Plate
Correction Plate -- 0.0762 mm (0.003 in)
Correction Plate -- 0.1524 mm (0.006 in)
Correction Plate -- 0.2286 mm (0.009 in)
For vehicles repaired under warranty, Brake Align® Run-Out Correction Plates should be submitted in the Net Amount at cost plus 40%. Brake Align® Run-Out Correction Plates are available through the following suppliers:
• Dealer Equipment and Services at 1-800-GM TOOLS
• Brake Align® LLC at 1-888-447-1872 (U.S. Dealers Only)
* We believe this source and their products to be reliable. There may be additional manufacturers of such products. General Motors does not endorse, indicate any preference for or assume any responsibility for the products from this firm or for any such items, which may be available from other sources.
WARRANTY INFORMATION
Important:
• Published labor operations include time to check run-out and road test vehicle after repair.
• Labor operation H9709 -- Brake Burnish is not a published labor operation and will not be found in the Labor Time Guide. This labor operation should be used to claim the necessary time for cleaning up the braking surfaces for thickness variation pulsation due to "lot rot" corrosion - refer to Brake Pulsation section of this bulletin for procedure. Thickness Variation Pulsation due to "lot rot" corrosion occurs when vehicles are not driven for an extended period of time. This type of corrosion clean-up is covered under the terms of the new vehicle warranty coverage.
Claims submitted using H9709 do not require LRO measurements.
• If correcting for LRO, claim the use of correction plates as OLH. The times for using correction plates are not to exceed 0.2 hr for one side and 0.4 hr for both sides. Guidelines for submitting OLH per General Motors Policy & Procedures should be followed.
• Model years 2005 to current -- labor operations H0120/1/7 and H0130/1/7, are to be used only when replacing rotors.
• Model years 2005 to current -- labor operations H0122, H0132, H0192 and H0202 have been established for Brake Rotor/Drum Refinishing.
• For model years in which the new labor operations do not apply, the time for refinishing the rotor is in labor operations H0120/1/7 and H0130/1/7.
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
H9709
Brake Burnish
0.2 hr
H0042
Pads, Front Disc Brake -- Replace
Use Published Labor Operation Time
H0043
Pads, Disc Brake-Rear - R&R or Replace
H0120
Rotor Asm-Front Right - Replace
H0121
Rotor Asm -- Front Left Replace
Use published labor operation time
H0127
Rotor Asm-Front Both - Replace
H0130
Rotor Asm-Rear Right - R&R or Replace
H0131
Rotor Asm-Rear Left - Replace
H0137
Rotor Asm-Rear Both - Replace
H0122
Brake Rotor Refinishing -- Front
H0132
Brake Rotor Refinishing -- Rear
H0192
Brake Drum Refinishing -- Front
H0202
Brake Drum Refinishing -- Rear
WORKSHEET -- BRAKE LATHE CALIBRATION
Important: Brake lathe calibration should be performed and recorded monthly.
BRAKE LATHE CALIBRATION CHECK SHEET
Dealer Code: _________________________
Date: _________________________
Lathe Type: ______________________________
Lathe Model:____________________________
What is the Lathe's Run Out?______________________
Is the Lathe within Specification? __________ Yes __________ No
Comments:
ATTACHMENT FORM -- GM BRAKE SERVICE REPAIR ORDER DOCUMENTATION FOR REQUIRED MEASUREMENTS
PART MEASUREMENT/REPLACEMENT DOCUMENTATION
Repair Order Number: _________________________
Front Rotor - ORIGINAL/REFINISHED thickness measurements (required when front labor operation is used):
• Thickness Specification (Min. Thickness/Discard Stamped on Rotor/SI): ____________________ inch/mm (Circle One)
• ORIGINAL measured thickness before refinish: Left Front (OLF)__________ inch/mm Right Front (ORF)__________ inch/mm
• REFINISHED measured thickness after refinish: Left Front (RLF)__________ inch/mm Right Front (RRF)__________ inch/mm
Rear Rotor - ORIGINAL/REFINISHED thickness measurements (required when rear labor operation is used):
• ORIGINAL measured thickness before refinish: Left Rear (OLR)__________ inch/mm Right Rear (ORR)__________ inch/mm
• REFINISHED measured thickness after refinish: Left Rear (RLR)__________ inch/mm Right Rear (RRR)__________ inch/mm
Rotor Replacement:
If rotors are replaced, you must indicate reason for replacement
__________________________________________________________
Pad Replacement:
If Pads are replaced, you must indicate reason for replacement:
LATERAL RUN OUT (LRO) DOCUMENTATION
Front Rotor (required when front rotor labor operation is used):
• LRO measurement after rotor refinish/replace: Left Front (LLF)_______________ inch Right Front (LRF)_______________ inch
• If above LRO greater than 0.050 mm (0.002 in), document correction plate part number used: Left ____________________ Right ____________________ (Example: 801-03)
Rear Rotor (required when rear rotor labor operation is used):
• LRO measurement after rotor refinish/replace: Left Rear (LLR)_______________ inch Right Rear (LRR)_______________ inch
but the second one is NOT a TSB, rather what to check for, corrections, yada yada.........
Hmm. I could swear that its coming from the drums but maybe not. I'd have to hear it from outside the truck. Thanks though. Good to know either way for when I take it to the dealer.
The first one is the one that applied to my truck and fixed my front brake squeal completely. The drums make a chirp every once and a while when they are cold but it is nothing compared to the howling the fronts were letting out!!
  • 1 month later...
Thanks for posting this as I am dealing with a dealer right now who is a never mind.
Front right inside pad worn down to the metal backing plate at 28000 miles end result tosted rotor. The wired thing this did not squel on bit or make a sound.
went back to my dealer today about the brakes. said his hands are tied since they turned down my rotors 500 miles ago. said gm will not pay for any more brake work untill a year has passed. my 07 has 4000 miles on it. they would not replace my rotors, i do not get it. they acutally turned them. still squeals like mad.
I recamened you cal the factory.
same thing happened to me. Dealer I went to is horrible and known for it as far as service dept. They were squeeling and it left grooves in one of my rotors..they said the could only turn them and resurface the pads and grease the slides. Still squeels, so i called GM and lodged a formal complaint about the dealer. There wasnt much they could do though since the dealerships are privately owned. No grooves yet though. I'll cross my fingers
Why on earth would they turn rotors to eliminate the brake squeal? Using some kind of anti-squealing paste would make a lot more sense. You could have tried it yourself. Auto Zone has CRC anti squeal paste for about $ 6 a bottle. Enough to do 20 vehicles. Just smear on the backs of the pads and let dry before installing them back.
As far as the statement that their hands are tied, still is utter BS. They did not fix the problem. If I bring a truck in for a squealing engine belt issue and they replace my water pump and nothing gets fixed, their hands would be tied too?
as for your squeaking belt:
Document ID# 1913537
2006 Chevrolet Chevy C Silverado - 2WD
Subject: Accessory Drive Belt Chirp, Squeal or Squeak Type Noise at Cold Idle (Replace A/C Compressor/Power Steering Pump Mounting Bracket or Enlarge Bracket Bolt Holes) #05-06-01-018A - (03/07/2007)
Models: 2004-2007 Chevrolet Silverado (Classic)
2006-2007 Chevrolet Express
2004-2007 GMC Sierra (Classic)
2006-2007 GMC Savana
with 6.6L Duramax® Diesel Engine (VINs D, 2 - RPOs LBZ, LLY)
This bulletin is being revised to add additional model years, models and update the technical content. Please discard Corporate Bulletin Number 05-06-01-018 (Section 06 -- Engine/Propulsion System).
Condition
Important: It should be noted that a chirp type noise on engine shutdown is normal for a diesel engine due to higher engine compression and the rapid stopping of the crankshaft. No repairs should be attempted for this condition.
Some customers may comment on an accessory drive belt chirp, squeal, or squeak type noise at idle, especially on a cold start. The noise may be reduced or go away after the engine warms up.
Cause
Some 2004/2005 Silverado or Sierra trucks, with a 6.6L LLY engine produced before June, 2004, may have an A/C compressor/power steering pump mounting bracket and power steering rear mounting bracket that are machined slightly out of specification, causing a misaligned power steering pump.
If the power steering pump is misaligned, it will force the accessory drive belt to run farther inboard on the fan pulley. When the belt leaves the fan pulley, the belt will not align properly to the crankshaft pulley grooves and create a chirp or squeak type noise at the point of interference.
Vehicles built after June 2004 will already have the new A/C compressor/power steering pump mounting bracket installed, but still may exhibit belt noise caused by the power steering pump rear mounting bracket.
Correction
Vehicles built prior to June 2004, replace the A/C compressor/power steering pump mounting bracket.
Vehicles built after June 2004, enlarge the rear power steering pump bracket bolt holes.
1. Follow the published service information (SI) diagnostics for drive belt chirping. The diagnostic chart for the drive belt chirping will ask to inspect for a misaligned accessory drive pulley.
Important: Remove the top section of the radiator shroud and TCM/cover to gain access to check alignment and measure the power steering pulley on the power steering pump shaft.
2. Verify that the power steering pulley is properly pressed onto the power steering pump shaft. Refer to SI for the power steering pulley replacement. If the pulley needs to be realigned on the power steering pump shaft, follow the published SI procedures for the power steering pulley replacement.
Object Number: 1664564 Size: SH
Click here for detailed picture of above image.
3. If the noise was not fully eliminated by the procedure in step 2, the power steering pulley may be adjusted with an allowable maximum variance of 1.0 mm (0.039 in) to the front from the flush position on the shaft to assist in eliminating any remaining belt noise. Refer to graphic illustration number 1 and number 2. Ensure that the power steering pump pulley illustration number 1 is flush against the power steering pump shaft illustration number 2, with an allowable variance of 1.0 mm (0.039 in).
4. If the noise was not fully eliminated by the procedure in step 3, and there are no other concerns found, follow the published SI diagnostics for drive belt chirping. Then, if the vehicle was built prior to June 2004 go to step 5. If the vehicle was built after June 2004, go to step 6.
Object Number: 1664146 Size: SH
5. Vehicles Built Prior to June 2004:
5.1. Replace the A/C compressor/power steering pump mounting bracket with P/N 97362175. Refer to graphic illustration number 1. Follow the published SI procedures for the Air Conditioning (A/C) Compressor and Power Steering Pump Mounting Bracket Replacement.
5.2. With the new A/C compressor/power steering pump mounting bracket installed, reposition the power steering pump to gain access to drill larger holes into the rear mounting bracket using a 14 mm (1/2") drill bit. Drilling the bolt holes larger will ensure proper alignment of the bracket when installing the bolts. Refer to graphic illustration number 2.
5.3. Install the power steering pump to the A/C compressor/power steering pump bracket. Refer to graphic illustration numbers 4, 2, and 1.
Important: Power steering pump front mounting bolts must always be tightened first to ensure correct pulley alignment.
5.4. Refer to graphic illustration number 4 and tighten the front power steering pump mounting bolts.
Tighten
Tighten the bolts to 50 N·m (37 lb ft).
5.5. Refer to graphic illustration number 2 and tighten the rear power steering bracket bolts.
Tighten
6. Vehicles Built After June 2004:
6.1. Remove the front and rear power steering bracket bolts from the A/C compressor/power steering pump bracket. Refer to graphic illustration numbers 4, 2, and 1.
6.2. Reposition the power steering pump to gain access to drill larger holes into the rear mounting bracket using a 14 mm (1/2 in) drill bit. Drilling the bolt holes larger will ensure proper alignment of the bracket when installing the bolts. Refer to graphic illustration number 2.
6.3. Install the power steering pump to A/C compressor/power steering pump bracket. Refer to graphic illustration numbers 4, 2, and 1.
6.4. Refer to graphic illustration number 4 and tighten the front power steering pump mounting bolts.
Tighten
6.5. Refer to graphic illustration number 2 and tighten the rear bracket bolts.
Tighten
Dual Generator System
New belts are not available for dual generator systems. If a belt chirp noise is occurring on a dual generator system, please complete a Field Product Report (FPR). The instructions for completing a FPR can be found in Service Bulletin Number 02-00-89-002F.
Parts Information
Part Number
Description
Qty
97386417
Bracket, A/C Compressor and Power Steering Pump Mounting
Labor Operation
Description
Labor Time
J7509*
A/C Compressor and Power Steering Pump Mounting Bracket - Replace
(Vehicles Built Prior to June, 2004)
0.7 hr
Add:
Enlarge Rear Power Steering Pump Bracket Bolt Holes
(Vehicles Built After June, 2004)
0.3 hr
Add:
Removal of Auxiliary Generator (if equipped)
0.1 hr
*This is a unique labor operation number for bulletin use only. This number will not be published in the Labor Time Guide.
as for the brakes, here is the warranty provisions (Same for factory parts)
ACDelco DuraStop Brake Limited Warranty
DuraStop Brake
Limited Warranty:
General Motors Corporation warrants to the original
retail purchaser of a DuraStop Brake System paid
repair --- that the original installing General Motors
Dealer will repair or replace any DuraStop brake
system product that fails due to a defect in materials
or workmanship for the following time and mileage
from the date of original installation:
Limited Lifetime Warranty for DuraStop Brake
Pads and Shoes – DuraStop Disc Brake Pads and/or
Drum Brake Shoes installed by your GM Dealer are
warranted against defects in materials, workmanship
and wear-out for as long as the original purchaser
owns the private passenger car or light truck (less than
8,600 lbs. GVW) on which the brake pads or shoes
were originally installed. The product will be replaced
one time as follows.
• During the first 12 months or 12,000 miles,
whichever first occurs, the one-time replacement
will be made free of charge including labor.
• After the first 12 months or 12,000 miles, whichever
first occurs, and continuing for as long as the
original purchaser owns the vehicle on which the
DuraStop product was installed, the one-time
replacement will be without charge for the cost of
the disc brake pads and/or drum brake shoes. The
labor to install will be the responsibility of the
original retail purchaser.
Wear-out under the provisions of this warranty is
defined as wear to the friction material within 1/32 of
an inch above rivets or steel backing on bonded
products.
All Other DuraStop Brake Products – are warranted
from the date of installation by the GM Dealer for 12
months or 12,000 miles, whichever first occurs. Repairs
or replacement will be performed by the original
installing dealer free of charge including labor.
The Original Purchaser’s
Obligations Are:
• Return the vehicle to the original servicing GM
Dealer or any participating General Motors Dealer
handling DuraStop brake products.
• Provide the dealer with the DuraStop Warranty
Card (friction products only) and the purchaser’s
copy of the original repair order showing the dealer
had performed a brake service using DuraStop
product(s) at an earlier date.
ARTICLE 1.1
PAGE 48
General Motors Service Policies and Procedures
1/02
Policies - ACDelco DuraStop Brake Limited Warranty
GM warrants DuraStop Disc Brake Pads and Drum Brake Shoes to the original retail
purchaser. The product will be replaced one time as follows:
- During the first 12 months or 12,000 miles, whichever first occurs, the one time replacement
- After the first 12 months or 12,000 miles, whichever first occurs, and continuing for as
long as the original purchaser owns the vehicle on which the Dura Stop product was
installed, the one time replacement will be free of charge for the disc brake pads and/or
drum brake shoes. The labor to install will be the responsibility of the original retail
purchaser.
- All other DuraStop Brake Products are warranted from the date of installation by the GM
dealer for 12 months or 12,000 miles, whichever first occurs. Repairs and/or replacement
include parts and labor.
- Dealer is to issue a Warranty Card (friction products only) along with a copy of the repair
order.
- Dealer is to verify warranty eligibility by requesting from the purchaser a copy of the
Warranty Card (friction products only) and the original repair order showing the dealer
had performed a DuraStop Brake installation.
- Durastop Brake Products are not to be used for new vehicle warranty.
Condition
Cause
Correction
Tighten
Tighten
Tighten
Tighten
Parts Information
Part Number
Description
Qty
97386417
Labor Operation
Description
Labor Time
J7509*
0.7 hr
Add:
0.3 hr
Add:
0.1 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
That's funny. I came up with a fictitious problem and you whipped out a service bulletin for it.
:lol:
No, I do not have any squeaking belts.
