Remote Start And Heated Seats
In trucks with remote start and heated seats, do the seat heaters come on automatically in cold weather when remote started?
My seat heater indicator was on -after remote starting- this morning (34 degs) but the seat didn't feel warm. Did I not give it long enought to warm up? After I put the key in the ignition, I had to turn the seat on myself and it sure did feel nice! I might use this feature twice a year here in Florida.
You have to give the seat heaters a few minutes to warm up. If the indicator was on, but the seats weren't warm yet, you probably hadn't given them enough time.
When I leave work on colder days, I'll try to start the truck as far away as I can. But, that's usually after I get to the same floor the truck is on, in the parking garage. If I get in and wait another minute or two, I can feel the seats warming up.
You are correct about having to turn them back on after you turn the key on. That's by design, although I'm not sure why. It'd be nice if they stayed on. Oh well! It's not that big of a deal to hit the button again.
Thanks, I guess I'll be more patient next time.
I have noticed this too. They are heating up, but the pressure of your butt brings the heat to the surface of the leather. With no pressure, the heat takes longer to surface and heat up the outer leather surface. That's why even if you enter the truck and do not turn them back on, in a minute or 2, you will feel the heat.
PS That has to be the goofiest reply I have ever posted. :cheers: But it's true. :dunno:
Is there anyway to disable the heated seats from coming on, when you auto start it? I don't care much for the heated seats.
I don't know how your seats are set up, but on my Sierra Denali, when you use the remote start, what ever was on when you turned the key off comes on with the remote start and turns off when you turn the key on. You then have turn them on again. (I.E. defrosters, AC, heater, or the heated seats) If the seats are off when you shut down, they'll be off when you remote start.
The heated seats are automatic on my SD when you use the remote start. They will come on if the temperature is cold enough. Same with the A/C in the summer.
Yes, it's automatic on my NBS GMC SLT as well. If it's below approximately 50 degrees the heated seats turn on automatically o matter what setting you had when you turned it off. When you put the key in and turn it they shut off and you have to hit the button again to turn them back on.
They work the same way on my wifes Acadia. Remote start and the heat kicks on but only when the temp is below a certain temp. Nice feature I think. As for disconnecting, you might see if there is a fuse just for the seats and pull it.
Pretty easy answer to turning the heated seats off. Put your key in and turn it. They go off. As stated, if you get to your truck quick enough, they won't get warm.
Here in the mid-west, the outside temp has to be under 40 F for them to kick on. (That's my best guess). They don't come on if its up around 50 but the 30 or so lately, they kick on.
Vmax2007 - Does the size of the individual account for the rate of heat to disperse to the leather :ughdance: . It's just funny....
Big guy = heats fast :lol: Little guy = cold ace for a while :ninja:
Have a wonder holiday season everyone!
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
