Steering Shaft Clunk Quick Fix
I gotta do this tommorow, I have been putting it off a while, didn't realize it was that easy I thought you had to remove the whole IMS shaft and re grease it but that sounds like a better fix to me.
went to the dealer amd they replaced mine... at least it looks new ... asked them for a receipt and it said they replaced it with a part #19153614.
.wonder if thats any good or it still sucks......
well i looked up the part number of gmpd and it says 99-07 1500 Fullsize truck upper steering column intermediate shaft... i guess it still work on a 2500hd
Yes, its really that easy. It literally took 5 minutes. Its funny, I asked my wife if she felt any difference after I did this and she said no. She never even noticed the clunk.... or maybe she's just got so used to it after 95k miles. :D
It's not like this is a new fix. As I recall the history of various "fixes" GM has had for the steering clunk that I've read about on this site, this was the designated fix between greasing it up and the current fix of replacing the intermediate steering shaft with a new GM part. The posting at the Silverado site was from late 2006. Yes, it sure helped my 2004 Z71 Tahoe, but I figure it's only a temporary fix. Personally, I won't give GM a shot on their new shaft. Another posting talked about a new Dorman shaft that should be available through CarQuest soon - I'd rather give my money a shot there.
I have been away from work for a few days, but we should have the new Dorman OE Solutions shaft in stock by now. I will check Wednesday and see if Dorman has started shipping them yet.
I did get to see one in person and from all indications, this thing will cure the problem. It is a very solid unit and looks to be well engineered. I have not seen one of the latest GM designed units to compare them.
I just did this to mine... 5 minutes and it worked, my truck is quiet now.. I ordered the current re-designed one like a week ago, atleast this will hold me over until that gets here... Since I've only had the truck like a month, I can't believe how quiet it is now... Night and day..
Any update on that Dorman OE Solutions shaft???
What is the correct torque figure for that bolt?
I posted this info about a "quick-fix" in another steering shaft thread...
All of you guys blasted me for even posting a quickie-fix
Instead of taking 4 minutes and fixing it ourselves, all of you wanted to go out to the dealer right away and piss away $80 for a new shaft...
I no longer have to stroke my shaft (nbs) but I may have to stroke my wifes "06" Tahoe "cough". but she has the new replacement, has about 24,000 miles on the new shaft and no clunk. Sorry Guys I couldnt resist.
I dont think you even have to take out the shaft to stroke it. If you push down hard on the steering wheel it will spring down and back about 1/2 inch. It appears to have taken away most of the clunk on our 03 GMC
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
