Dissapointed In Bose Stereo
I bought my truck thinking the stereo wouldn't have to be replaced to get some good sound and I have the steering wheel controls to boot. Now to get good sound should I either replace the speakers to begin with or the head unit?
Replacing the speakers wont do anything for you, unless you put an amp on them.
If you put a high quality head unit in it will make a good amount of difference on the volume, but will distort your factory speakers, if played to loud.
When upgrading a stereo with Bose, your best option is to just replace the whole system. You can keep your steering wheel/onstar/door chimes with a harness.
What do you mean by good sound. The problem with BOSE if that's what you have is invidual components are nothing by themselves, and are designed to work together, the odds of replacing the Head Unit or the Speakers invidually will result in less than the desired outcome are very high.
What do you mean by "GOOD SOUND", is this a quality of sound problem, or a level of sound problem?
I personally dislike anything BOSE and for the same amount of money an "upgrade" or complete system costs, I can always do better with something else. Been through it both with car audio and home theater. They are good at what they do, and their marketing can't be beat and for most people they are more than satisfactory. But they have their limits.
Do yourself a favor and go to an audio shop for an opinion, a good one will listen to your issues and address them, usually more cost effectively than piece mealing a system, you may not be satisfied with in the end.
Good sound I mean quality. I guess once you've had a system with quality sound you can tell the difference. I had a pioneer set-up in my last truck and you could adjust the sound with mulitple controls and my system sounded great. Best buy told me that when replacing the bose system it's a pain in the arse. I think I'm looking at some bucks to get the quality sound I'm after. That's why I'm a dissapointed.
Please step away from the Best Buy. :(
Go to your smaller independant shop for better information as well as equipment. Most all shops have equipment in the same price range as Best Buy, but will be better quality.
You will need to replace your radio and all of your speakers, add at least a 2 channel amp for the front components and if you run rear speakers you can either use a 4 channel for all of them or run those off the rear outputs of the deck. I have not confirmed this yet, but you may need to have all new speaker wires run.
For the price of the Bose upgrade you can actually get a decent system installed. Personally I would save up and install both a head unit and speakers, since you have the BOSE. I stay away from their stuff so I don't know how much they have it "tweaked" to optimized their "system", but it may be salvageable by doing the amp with crossover to new speakers and sub. The shop I work with would let me run all the wiring and terminate at the kick panels where they would pick up and pull the wires into the doors. The most time they invest is pulling apart interiors to run wires so you may suggest it as an option if it's something your comfortable with.
I always install an amp, and a sub. I don't thump my music, but on a non-bose factory system, even with stock head unit and speakers, an amp with a cross over taking the bass off the stock door speakers and giving them more power makes an amazing difference. This gives me time to decide on a head unit and speakers for phase II or III of the upgrade. Go ask the pros, most of them will listen, if not find someone else. In my experience, they really want you to be happy with your tunes, and the best ones will work with you. Discuss the option of phasing your upgrades and be honest, you will sense whether you found the right shop or not!
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
