Tsb#050307006
Could some one print TSB #050307006 out for me. It has to do with front end alignment. I am having trouble with neg camber. I think the Firestone store is full of it.
Thanks so much
Grumpy Old Man,
Don
Thanks so much
Grumpy Old Man,
Don
Document ID# 1666635
999999995.gifSubject:Revised Wheel Alignment Specifications #05-03-07-006 - (05/31/2005)
Models:2005 Chevrolet Silverado
2005 GMC Sierra
This bulletin is being issued to revise the Wheel Alignment Specifications in the Wheel Alignment sub-section of the Service Manual. Please replace the current information in the Service Manual with the following information.
The following information has been updated within SI. If you are using a paper version of this Service Manual, please make a reference to this bulletin on the affected page.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1666635&evc=numSrch#tab1-1666635">
Truck Line
Model
Caster L-R
Cross Caster, L-R
Camber
Cross Camber, L-R
Toe
Steering Wheel Angle
Important: Caster is relative to frame. The caster values must be compensated for the measured frame angle. Frame angle is positive when higher in the rear and negative when lower in the rear. Refer to Front Caster and Camber Adjustment.
C1500
Silverado, Sierra w/16" Tires
Reg, Ext Cab or Crew Cab
3.75° ± 1.00°
4.00° ± 1.00°
- 0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
- 1.0° ± 3.5°
C/K 1500
Silverado, Sierra w/17" Tires
3.85° ± 1.00°
4.00° ± 1.00°
- 0.15° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
- 1.0° ± 3.5°
C1500HD
Crew Cab
4.50° ± 1.00°
4.75° ± 1.00°
-0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
-1.0° ± 3.5°
K1500
3.80° ± 1.00°
4.10° ± 1.00°
- 0.30° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
- 1.0° ± 3.5°
K1500
3.60° ± 1.00°
4.30° ± 1.00°
-0.70° ± 0.50°
+0.25° ± 0.50°
0.00°± 0.50°
+0.10° ± 0.20°
- 1.0° ± 3.5°
K1500
Sierra Denali w/20" Tires
3.50° ± 1.00°
4.50° ± 1.00°
-1.00° ± 0.50°
- 0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
- 1.0° ± 3.5°
C1500/K 1500
Silverado/Silverado SS/Sierra, w/20" Tires
4.10° ± 1.00°
5.10° ± 1.00°
-1.00° ± 0.50°
-0.10° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
- 1.0° ± 3.5°
K1500HD
Silverado, Sierra
Crew Cab
4.25° ± 1.00°
4.50° ± 1.00°
-0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
- 1.0° ± 3.5°
C2500LD
Silverado, Sierra
Reg or Ext Cab
4.50° ± 1.00°
4.75° ± 1.00°
-0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
- 1.0° ± 3.5°
K2500LD
Silverado, Sierra
4.25° ± 1.00°
4.50° ± 1.00°
-0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
-1.0° ± 3.5°
C2500HD
Silverado, Sierra
4.25° ± 1.00°
4.50° ± 1.00°
-0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
-1.0° ± 3.5°
K2500HD
Silverado, Sierra
4.25° ± 1.00°
4.50° ± 1.00°
-0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
-1.0° ± 3.5°
C3500/3600
Silverado, Sierra
4.25° ± 1.00°
4.50° ± 1.00°
-0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
-1.0° ± 3.5°
K3500/3600
Silverado, Sierra w/Dually
4.25° ± 1.00°
4.50° ± 1.00°
-0.25° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
-1.0° ± 3.5°
K3500/3600
Silverado, Sierra Non-Dually
Reg, Ext Cab
4.50° ± 1.00°
5.00° ± 1.00°
-0.50° ± 0.50°
+0.25° ± 0.50°
0.00° ± 0.50°
+0.10° ± 0.20°
-1.0° ± 3.5°
C/K 1500
Silverado, Sierra with Rear Wheel Steering -- Values are for the rear of the vehicle.
-0.50° ± 0.50°
0.00° ± 0.20°
-1.0° ± 3.5°
Thrust Angle
0.00° ± 0.15°
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gifWE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
