What's Needed For Xm Swap?
I currently have the cd/radio in my NBS 07 now. What components are needed to have the XM? I'm assuming just the XM module? I have a chance to buy a module from a local 07 NBS, but is the module all i need to get the XM service? And if so, will the module plug just simply plug into my cd player? Thanks
The XM kit available from GM includes the XM receiver, receiver bracket, a replacement Onstar/XM antenna, a wire harness, a couple of bolts, coax antenna lead, and instructions.
Just the module alone, will not suffice. I don't know if the other parts beyond the receiver are available outside of the kit. You have to drop the headliner, pull the radio, drop the glove box, replace the antenna, run the coax lead, and plug the harness in. The hardest part of the install, is mounting the bracket to back side of a cross beam behind the glove box. Took me about an hour and a half to do the install.
